change MTF 6speed for TSX 09-10
WTH happened to my garage
Drain plug is on the bottom of the tranny case, looks like a 1/2" square that your ratchet or breaker bar fits in, make sure to park on a level surface before draining.
To fill, remove the 1/2" square plug on *the side* of the tranny, fill until MTF comes seeping back out, then put the plug back in. Your capacities should be listed in the owners manual.
Some people here like the GM syncromesh, I've always used Honda MTF (it has a gear lube additive, unlike 30 weight oil that some numbnuts use)
Ok, I'll go with 62,500!!! Hahaha Thank you!!!
Seriously, this is my 5th manual transmission car and always change the transmission fluid around 50k. I asked because I didn't find anything in the manual. Thank you!
oh and this... this is for my 6MT in my RSX but I can't imagine it would differ that much. You will notice the first time maintenance action "F" is shown is down at 120,000 miles or 6 years and "F" is change manual transmission fluid.
Motto to live by: "When in doubt change the transmission fluid"
![](https://dl.dropbox.com/u/4239286/AcuraZine/change%20transmission%20fluid%201.jpg)
![](https://dl.dropbox.com/u/4239286/AcuraZine/change%20transmission%20fluid%202.jpg)
divac
08-29-2018 10:13 AM
mugen_kid
11-13-2015 10:38 PM
