brake paddle release sound
I own a 2011 tsx, since the temperature started dropping, when I drive in the morning, I can hear some weird sound after I release the brake paddle (the sound is not from the paddle. It sounds like grinding, or some place lack of oil, I can't really describe the sound, but I've heard similar sound from other cars, e.g., Accord, Prius, Mercedes r), however, it only occurs in the first few stops, once the engine temperature raise up, the sound is disappeared, I'm not sure if this is normal in the winter, or I should have a check at local dealer?
Anybody else encountered similar issue?
I have a 2009. I know what exactly you are talking about. I did have this sound since i own the car. I did take it to dealer. you know same BS. it is normal. dealer told me it will go away when you put more miles on it. Now I have 28500 miles. It did not happen that often, but I still hear few times a day. I would suggest you take it to dealer see what they say to you.
xyz2011basilisk (01-05-2012)
I've had the same problem when not driving my car for a while (like a week) which should be normal from the brake corrosion. However, if your driving your car regularly and the problem still persists, you should get it check out.
09-15-2015 06:44 PM
