Bad battery?
Old Sep 2, 2012 | 12:43 PM
Johndoyle's Avatar
Bad battery?
So, my sister's G1 TSX was totaled. Found an '09 CPO Tech for her and bought it. Yesterday, while setting up some of the tech stuff (it took me a while), I started and stopped the engine several times, left the ignition switch on (which switched on HID lights and AC condensor fan as well) while trying to do settings, set up homelink, etc. When I went to start it, dead battery -- no crank. I put my charger on it for about 45 minutes, after which it fired up and I took it for a ride. We just got the car after it had been sitting on a dealer's lot since June. It was in service 2 years and 10 months. Do you think the battery should be able to take more abuse than that or should I get a new one before winter? I appreciate your opinions!
Old Sep 2, 2012 | 01:01 PM
robpp's Avatar
Graphite Ghost
oem battery's suck.
that said, you should get about 4-5 years out of it.
I would put it on a good charger, fully charge it, and drive it some. if it holds the charge then you good....if not...you know what to do/
Old Sep 2, 2012 | 01:03 PM
ed_423's Avatar
SeeYou2Crew #2
+1 ^^
Old Sep 2, 2012 | 01:17 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
OEM batteries are horrible. i've gotten about 3 yrs of life out of the 2 i had in my TL then they started to go. it is not uncommon for early death of the OEM batteries in acuras. you're lucky to get to 4 or 5 yrs. my avg life was 3 yrs. some get them last 5-6 yrs, some only get a yr.
if the battery holds a charge then great...if not...well...consider going after market with a battery that has better cranking power. i have yet to see an OEM battery last the 100 mos they claim.
Old Sep 2, 2012 | 01:53 PM
PyroDave's Avatar
my OEM battery died before my second winter in my 2010 base TSX lol
Old Sep 2, 2012 | 02:45 PM
Johndoyle's Avatar
I'm going to give it a good charge and see how it responds, but I think I'll pick one up before the winter. I'd normally replace it at four years anyway, so it's not that early.
Old Sep 2, 2012 | 03:28 PM
Maesm81's Avatar
You have to let the battery charge completely. Otherwise you are doing more harm than good. Let the battery charge on the lowest setting (probably 2amp) of your charger, and let the charge complete before you remove it.
When the charge is complete put a multi-meter across the battery and check the voltage drop. Never had to do this, but I am guessing around 10v should be ok. Anything less the battery is weak and should be replaced.
Old Sep 2, 2012 | 04:24 PM
nj2pa2nc's Avatar
it's a car-drive it
When I had my tsx inspected in Jan. 10 the dealer replaced the battery free. They told me it tested low even tho I did not have any problems with it. On the 2nd battery-still good (knock on wood)
Old Sep 2, 2012 | 04:33 PM
youmadeyou's Avatar
I agree .. when ever I buy a car with a OEM battery (weather it be new or used car) I always replace the OEM battery with a better brand battery and then Sell the OEM battery .. I have had many bad Experiences with them so i know longer waste my time..
Old Sep 2, 2012 | 06:08 PM
The Dark Knight's Avatar
My OEM is going 4 years strong.
Any battery recommendations for what I should replace it with when it goes?
Old Sep 3, 2012 | 12:10 AM
09TSXTech's Avatar
OEM battery is not the greatest. However, Acura offer free replacement for 4 yrs/50K miles. So bring it back to the dealer, let them do a load test, if it's defective, they will install a new one free of charge. I had mine replaced when it's 30 months old.
Old Sep 3, 2012 | 12:12 PM
musty hustla's Avatar
FYI you don't have to turn the car on to set up the tech features.
Old Sep 4, 2012 | 02:04 PM
Johndoyle's Avatar
What do you do, turn it to accessory? I had it in the "on" position, engine not running, which is what I think caused all my troubles.
Old Sep 4, 2012 | 02:15 PM
EL19's Avatar
Turn the lights and AC fan off LOL
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
hrothgar02
Sep 28, 2015 11:08 AM
mars
Sep 28, 2015 11:03 AM
