Auto vs 6mt rpm at 65 mph
The dealer gave me a loaner with auto transmission. I noticed the auto at 65 mph is barely over 2000 rpm. My 2012 SE 6MT is closer to 3000 rpm at 65 mph.
Can you 6MTers confirm this?
I did search but nothing came up. If this question has been asked before, I apologize.
Thanks.
Thanks.
V6 is at ~1500-1800
All three drivetrain combinations (4 cyl AT, 4 cyl MT, 6 cyl AT) each actually have different gear ratios in the transmission, and different final drive ratios. End result being, in top gear.... 4 cyl AT: 2.53, 4 cyl MT: 3.28, 6 cyl AT: 2.11. Pretty big difference between the MT and the AT cars. My wife and I both do almost all highway driving, and this (the considerably higher gearing of the AT) was a major factor in our choice of AT cars. Probably not a huge factor at 65, but at 85-90, I have to assume that the MT car is pretty buzzy (and the mileage takes a big hit too, even more so than in the AT car).
Why? It would be a dog having to accelerate on the freeway. Mileage is great as-is, and noise level isn't high. What would you gain?
It's not the taller 6th gear you want, it's the lower final drive ratio.
Stan
Stan
You can always downshift.... And that's a higher final drive ratio (lower numerically) you'd want to decrease revs at speed. Honda has always (I mean for like over 30 years) used pretty close ratio transmissions with a low ratio (high numerically) final drive. That tends to minimize rev drop between shifts and it keeps the engine closer to the torque and HP peaks. I happen to think it's a great plan, but it can take it's toll on revs at cruising speeds with the MT. Honda engines have also always been weak in the torque department, so the lack of a torque converter necessitates the lower gearing of the MT.
This is not a complaint by the way. I just wanted to confirm with other MT owners the RPM range. I will take a MT any time for a more engaging driving experience. I just didn't know the difference between auto and MT is that much as I didn't test drive an auto before.
Simba - thanks for the technical explanation.
But you'd have a bigger gap between 5th and 6th.
I actually like higher RPM at speed in lower power car, it is more responsive. I don't want to downshift to 5th at 70MPH to 5K RPM or wherever that would end up. I don't want to downshift on the freeway at all, I never have to in any of my cars.
Stan
Stan
I'd say what you are seeing RPM-wise is correct. I'm running about 3000 between 65 and 70 mph. I was always curious what the rev differences would be between my 6MT, the 5AT and the V6 at various driving speeds. I always thought that mine revved a little high, but I wouldn't change a thing. This thing is still a blast to drive.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
