anyone tried an HID kit with a direct wire relay for DRL??
Old 01-25-2013 | 11:33 AM
  #41
bagwell's Avatar
2010 TSX
Originally Posted by mrstak
lemme guess? each one of those lights are hid right?
correct, all 55w HID
j/k
not my jeep either.
Old 01-25-2013 | 03:12 PM
  #42
potmilkz's Avatar
j/k
not my jeep either.
well obviously haaha if you worked at delta lighting and was able to hook up all those lights on that jeep, you should not be asking how to wire up some lights here on the this thread..
but yea as i explained you can do it, just requires relays.
Old 01-25-2013 | 03:46 PM
  #43
robpp's Avatar
Graphite Ghost
sorry but it will require MORE than a relay. you cannot trigger a 12v relay with 3 volts that come from the drl wire.
I have tried it on my '12.
it will require someway to convert 3.6 volts to 12 for your 'relays' to fire/
see my post.......the CORRECT one above yours/
Old 01-25-2013 | 06:05 PM
  #44
potmilkz's Avatar
see below..
looking for a simple way to run HID as DRL at full power. I NEVER used flash to pass so that's not an issue for me.
thanks for any help.
do you not understand that the OP does not want the DRL function? He only wants HID to run as Low beams at 100%.. my method works, your method works too but your method is useless to HID bulbs.. keep in mind.. there is no point of having flash function as it is not recommended to turn bulbs off and on..or even flash them as it harms the bulb.
a direct wire without using the stock harness does work.. apparently you never did a direct wire. Please read and understand the thread.. ill quote myself again just for you..
but to answer your question, wire it up directly to the battery with a relay. have the lead connect directly to the ignition slot in your fuse box with a switch inbetween.
each of our methods work depending on what you want..
if you want full control of the DRL HID bulbs, do it my way.. if you want the DRL HID bulbs to turn off when the low beams turn on, then do it rob's way.. but op never mentioned neither.. so both methods work.. saying mine dont work is ridiculous as it has been done by many members here not just for DRL but for fogs, reverse lights, etc.
Old 01-25-2013 | 09:10 PM
  #45
ed_423's Avatar
SeeYou2Crew #2
pyro wtf was that LOl
Old 01-26-2013 | 01:53 AM
  #46
PyroDave's Avatar
a dick measuring contest... i think i won.
i mean light measuring...
i mean...
PRETTYCOLORS
Old 01-26-2013 | 10:17 AM
  #47
bagwell's Avatar
2010 TSX
http://www.xenonsupply.com/products/...g-harness.html
Old 01-28-2013 | 08:39 AM
  #48
mrstak's Avatar
7# werC 2uoYeeS
lol pyro are you gonna take those lights off when you return the lease? transfer to the new car?
Old 01-29-2013 | 01:49 AM
  #49
PyroDave's Avatar
completely new setup for my next car. just gotta figure out what im getting
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
01CLOwner
10-09-2015 01:07 PM
JnC
09-11-2015 06:06 AM
spiel08
09-07-2015 08:19 PM
Quick Reply: anyone tried an HID kit with a direct wire relay for DRL??
