Adam's rotors AR Race Double Slot
Its a long story so I wont bore you here but
Big Props to Adams Rotors for taking care of me
check out Adam's Rotors for braking needs; he is a forum supporter and deserves a look!
these double slot rotors are as quiet as OEM....I do not know they are on except when its important.
I also have the StopTech replacement pads THey are ceramic pads like the OEM ones and I would expect the same wear.
I cant wait to get my SUMMER WHEELS ON!
OK OK some pics
the front during install
the rear during install
close up of rear slots
front wheel on ,,,,,stockers with snows.
rear wheels on
I followed adams bedding procedures to the T. I went to an induistrial area on the weekend where no traffic, did my 10 60-10-60 stops and this road is right near a highway entrance so i did the stops and hit the highway 75 MPH for like 15 miles so they get a good cooling off.
here some pics after the bedding
pedal feel is the same in regular driving.....but the bite is there when I need it. I started commuting through downtown to a new gig and had to use these twice already/
i want to now clean them all up and paint my calipers black and get the SS brake lines to increase the pedal feel.
OK OK some pics
rear wheels on
Cool pics and review. I am still in the market for a BBK... Traveling so much right now, hard to get anything really going.
Great post man! I am looking into AR rotors as well so this review has really helped my decision. So upgrading just rotors and pads creates a noticeably difference in braking performance you think?
Former Sponsor
wow!
thanks for the works & great photos...they look killer.
let us know what you or anyone else may need regarding brakes!
-a
-a
Former Sponsor
bagwell, our storefront has your TSX's pricing & options loaded.
have a look here: www.adamsrotors.com/store
if you have any other questions, please let us know via email!
thanks
-a
thanks
-a
ROTAREDOM
I have stop tech drilled rotors and hawk performance pads, and they make hell of a difference. I definitely feel safer, and the annoying shaking went away. I have done some pretty hard stops and they have surely kept me from getting into a crash. Definitely worth upgrading.
ttk5 (02-11-2013)
Thanks SSjoe. That sealed the deal for me..I will add rotors to my wishlist.
Nice looking rotors. I would leave the screws off next time tho. You dont need them since they are only for the factory line to keep the rotors on while the car travels down the line. Its always a pain to take the brakes off when those dang screws rust!!
Let us know how they hold up in the next year.
thanks for the tip HOWEVER if you are any type of a mechanic you might have known that putting a dab of anti-seize on the screws will make them totally removable forever.
in a year put up some cash and we can have a bet if I can remove them
without the screws there is a possibility of the rotor falling off when you are doing the brake pads the next time....
So why did you switch from the dimpled set up to this one? I was doing some research on brakes and saw that you had the dimpled ones just back in December.
Former Sponsor
^ dimpling (and drilling) do nothing but look good, they have no performance benefits.
slotting (particularly our double slotting) have great heat dissipation, glaze avoidance, and added bit.
it truly is one of our best performing patterns & easily our most unique being a totally exclusive pattern.
Former Sponsor
it just doesn't...
drilling was designed to break-up pad gas, old race compounds used to create.
it would effectively create a pocket or cushion between the pad & the rotor surface otherwise, drastically effecting your bite.
this was a fix.
but new age pads simply don't create this gas...now it's purely for aesthetic.
...which is all fine & dandy & more than adequate for 90% of you & your daily driving needs, but just don't expect any gains; slotting is where it's at.
this was a fix.
Look at Formula 1 and Indy rotors....they do not have any drilled holes nor slots. What does that tell ya?
I ran Hawk HP10s on my stock WRX TR rotors and had no issues with bite on the Le Mans course at TMS. HP10s are 1 step below Indy Car grade.
I would just use slotted if anything. They look good and do some good over non-slotted with street and simi race pads in my experience. Drilled rotors tend to crack a lot easier and faster than non-drilled/non-slotted and slotted rotors
You also cannot service ceramic. No machining for those.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
09-25-2015 06:14 PM
