Acura TSX AD claims Active Sound Control on the TSX
Old Feb 18, 2010 | 02:47 AM
TheGoodGuy's Avatar
This ad of course is for the 2010. I suspect our 2009 has it too (i've heard it kick in the morning as I start my car).
http://www.youtube.com/watch?v=XoB2zhgcQqY
Dealer claims the TSX does not have it, only the TL.
The reason I ask - on a long drive I need that thing shut off, it puts me to sleep if I am super tired.
Old Feb 18, 2010 | 04:51 AM
HHCZ's Avatar
wow. I have never heard of this feature on any car ever (but I know this technology). I doubt that Euro has this
Old Feb 18, 2010 | 07:54 AM
thunderbt3's Avatar
Maybe only the V6 TSX has this feature. The video shows 6 cylinders and V6 engines. The car at the end is the V6 version with US V6 wheels.
Old Feb 18, 2010 | 08:32 AM
chibianh's Avatar
only the V6 TSX has this.
Old Feb 18, 2010 | 12:00 PM
HeavyDuty's Avatar
WTH happened to my garage
A friend has that active cancelling deal on his 08 TL-S. He had to defeat it when upgrading the stereo because it was causing a bunch of problems.
I think the Accord V6 has it to, to cancel out the harmonics from the multiple dislacement system (6/4/3 cylinder operation?)
Old Feb 18, 2010 | 12:08 PM
Colin's Avatar
^^no, it primarily serves to help cancel out low frequency noises like exhaust resonance, tire noise etc. V6 TSX only. Others include top models of Odyssey and Accord (where it might also help with VCM), TL, RL and ZDX.
I still wonder why the changed the name from Active Noice Control to Active Sound Control? LOL although by itself, "noise" is not politically correct in a car, "noise control" is. Gotta be some ad copy writer...
Old Feb 18, 2010 | 01:09 PM
crazyasiantl's Avatar
the 09 loaner i just had had some kind of feature like this..i think. it said it was only available through a different input. didnt work on am/fm and xm wasnt active
Old Mar 24, 2011 | 09:57 AM
fallacy's Avatar
Bump, anyone know if the 4cyl has this?
Old Mar 24, 2011 | 10:04 AM
KillerG's Avatar
Op is too busy to care
if anyone with a v6 locates the speaker we i4 owners can check if its there, i highly doubt it tho
Old Mar 24, 2011 | 10:55 AM
thunderbt3's Avatar
4 Cyl does not have this. Colin confirmed it above.
The speakers are the same ones that regular audio comes out of, no special speakers for the active noise canceling.
Old Mar 24, 2011 | 09:26 PM
DJMcGee's Avatar
The real question - can it be retrofitted into I4's??? It must be an input to the stereo system and maybe some activation. I cannot imagine the low volume V6 has a separate audio system.
Old Mar 24, 2011 | 09:34 PM
KillerG's Avatar
Well, the sounds never bothered me...infact i am looking for ways to make my car louder haha, but if you want increased sound dead DJMc, an easy mod to do would be to open the door panels and add sound deadening material to them, ive seen them done on other cars and might achieve a similar effect to a noise isolation system.
Even if we can retrofit it the system appears to work by producing resonant frequencies which neutralize the equal and opposite frequencies produced by the engine, so even if we got it to work wouldnt it need to be producing a whole different set of sounds to quiet the I4?
Old Mar 24, 2011 | 11:37 PM
katmai's Avatar
Its only the V6 TSX. It only reduces low end hum. It doesn't reduce sound across all frequencies. Its similar to noise canceling headphones you can buy at the store. It won't get rid of everything. The system uses another mic in the sunglass holder area and your regular audio system for the output. You can't turn it off.
Old Mar 25, 2011 | 12:37 AM
b.ike's Avatar
Well for the 2010 models, the brochure only marketed this feature for the V6 models.
Personally I'm kind of mixed on this feature. It good at dampening a bunch of sounds and it makes driving alone at night rather "interesting" for lack of better description; but at the same time I feel I'm missing out on hearing the V6 engine roar as the low end sounds are muffled. Only when I rev hard do I realize my engine actually exists lol
Old Mar 25, 2011 | 12:43 AM
KillerG's Avatar
there is probably a fuse you might be able to disable, check your manuall
Old Mar 25, 2011 | 01:25 AM
ParaSurfer1979's Avatar
Odd the 4cyl TSX does not. My 08 accord ex-l had it as well. all 190hp k24s and v6 had it. The 177hp k24 does not.
Old Mar 25, 2011 | 01:29 AM
I had to unplug the 2 mics when i installed my amps. It caused a humming at 3k rpm.
Old Mar 25, 2011 | 08:26 AM
KillerG's Avatar
thats odd that the accord had it but we didnt at 200hp... only thing i can think of is that it was cheaper for them to use sound deadening material...but then again why didnt they do that in the ex-1 accord?
Old Mar 25, 2011 | 10:09 AM
fanmm's Avatar
TSX vtec 4 doesn't have that much noise to begin with, I am not sure if it works on road/wind noise or not. that could be something more useful than just reduce engine sound
Old Mar 25, 2011 | 10:21 AM
Has nothing ton do with power. Its about add droan/noise when honda gave the accord coupe and EX 4cylinders have bigger piping to get the 190hp. The TSX's dual exhaust relieves this issue i'd think which is the reason why the TSX 4cyl doesn't have it. The droan only happens at 3-4k rpm then it's gone. Highway speeds are no different or speeds below that. The TSX V6 gets it because the Sound issues that were in the TL-S are happening with the same motor in the TSX. Don't forget guys that its the same motor.
Old Mar 25, 2011 | 10:22 AM
It does not help wind/road noise...
Old Mar 25, 2011 | 07:42 PM
katmai's Avatar
I would think in a "sporty" car you'd want to hear the lower end sounds. The TSX 4 cyl is very 4 cyl-ish sounding for lack of a better term! lol It definitely doesn't have the smoothness of a V6.
mada51589
Jan 9, 2025 04:40 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
nuldabz
Sep 3, 2015 05:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
