91 or 93?
91 or 93?
Hey guys, just wondering about this. I know our tsx are suppose to be filled up with premium (or so it says it should) im just wondering if using 91 or 93 is a big difference. I just got my car and my first fill up, I gave my baby 91 cause thats the highest they had at that gas station. I know theres a Chevron that has a gas above 91
This is from that little book that everybody gets with the car but nobody ever reads.
Fuel Information
■ Fuel recommendation
Unleaded premium gasoline, pump octane number 91 or higher.
■ Top tier detergent gasoline
Because the level of detergency and additives in gasoline vary in the market, Acura endorses the use of “TOP TIER Detergent Gasoline” where available to help
maintain the performance and reliability of your vehicle. TOP TIER Detergent Gasoline meets a new gasoline standard jointly established by leading automotive manufacturers to meet the needs of today’s advanced engines. Qualifying gasoline retailers will, in most cases, identify their gasoline as having met
“TOP TIER Detergent Gasoline” standards at the retail location. This fuel is guaranteed to contain the proper level of detergent additives and be free of metallic
additives. The proper level of detergent additives, and absence of harmful metallic additives in gasoline, help avoid build-up of deposits in your engine and emission control system. For more information on top tier gasoline, visit www.toptiergas.com.
Fuel Information
Acura_Dude (08-14-2012)
It's mapped to run on 91 minimum and with timing advanced as far as possible. If you go from 93/92 to 91 it's not going to pull timing (it probably will if you go to 85 octane to help keep from pinging/knocking; i.e., the knock sensors will retard timing.)
Anything over the 91 minimum is a complete waste of money. It will not do anything for the motor unless you get a tune that will actually maximize using higher octane (run more timing.)
But if you feel better using higher octane, then more power to you (but not to your motor.)
i use 93 like others say to them it seems like a waste of money but i tested it out for myself and i get better mileage out of the 93. 91 burns quicker and i feel a differnece either way an extra 8 - 15 cents isnt saving much so why not run 93
7# werC 2uoYeeS
did you drive in the exact same conditions in both runs? exactly the same speeds and traffic and everything? i mean unless u did that, your results are pretty ymmv. i remember ceb posted a link a while back with proven scientific data/tests that getting a higher octane gas did nothing for gas mileage and in some cases could even produce worse results.
Heh, that could mean that the car was able to advance timing more using 93. Wish I had 93 octane to try it out, if I ever run into it I will.
Though if 93 didn't have ethanol in it and 91 did, that would explain your mileage gain. I'd be tempted to run non-ethanol gas vs. gas with ethanol in it, no matter if it was 91 or 93 (granted all the options were premium).
Stan
Stan
im using iseeyoutwo's 4.09(93) gas price lol :-p to fill up from e will be $75.66
(91)3.94 - .15 cheaper fill up from e will be $72.89 so all you would be saving is $2.77 each fill up not much of a help in my eyes since its only a little over half a gallon. so to each his own, to me if i wanted to skimp on gas i would of kept a civic with a d15 in it
iSeeYouTwo (08-13-2012)
Better gas mileage from 93 over 91 is in one's mind, sorry. There's no technical reason why one will get better mpg. The timing remains the same and the fuel is burned identically. The TSX motor is designed to run properly on 91 octane without any needed timing changes.
And $2.77 per fill up can be of value for someone commuting 50+ miles plus per day.
But sure, do what makes you feel better. No problem there. That's 95% of why consumers make the choices that they make everyday, and why advertising is so incredibly effective.
imKing (08-15-2012)
But the fact is, you're not skimping on gas. You're simply using something that's more than required and not necessary. It's like buying more expensive soap that has nice smelling additives rather than choosing which actually cleans well.
The article that was referred to earlier had this quote regarding a test of regular vs premium fuel:
"The Accord took a tiny step backward in power (minus 2.6 percent) and performance (minus 1.5 percent) on premium fuel, a phenomenon for which none of the experts we consulted could offer an explanation"
They concluded with:
"Our tests confirm that for most cars there is no compelling reason to buy more expensive fuel than the factory recommends, as any performance gain realized will surely be far less than the percentage hike in price."
That clearly negates all of the non-scientific tests by forum members that claim any noticeable increases in either power or mileage when using 93 vs 91.
will make a world of difference then you should just take public transit .
MY OPINION ( there like assholes everyone has one ) pce
93 above all
HOLLYHOOD (08-13-2012)
I was going to a station near me for a while that had both 91 and 93. I ran 91 for a few fill ups, got close to E each time, and then tried 93 for a few. I kept my commute exactly the same, etc., and I did notice a slight increase in MPG (and the car did feel just a tiny bit more responsive). The MPG increase was nothing too dramatic, but enough that I don't feel like I am completely throwing money away every now and again when I choose to use 93.
justnspace (08-13-2012)
AZ Community Team
Fuel Information
Fuel Information
When you get a bit older and wiser, and have to take care of yourself on your own dime, you might think differently.
Gain some maturity, car ownership experience, and better language skills, and then come back later for another try at making worthwhile contributions.
I feel like I've wandered onto a high school playground.
The following 2 users liked this post by turning japanese:
justnspace (08-14-2012),
tvac (08-15-2012)
Initially, when I first purchased the car, I was using 93 octane which contained 10% ethanol. . The car ran great and I felt the mileage was decent.
Recently, a few stations in my area have begun selling non ethanol 91 octane, so I figured I'd try it out to see if I noticed any difference. The car continued to run fine with 91, and I noticed no appreciable changes in performance, either positive or negative. I did, however, notice a decent increase in overall miles per tank. That's OK in my book...
^^Makes total sense. I so wish we had some gas without ethanol in it somewhere nearby so I can see what difference in mileage it makes -- as-is this car is returning awesome mileage to me so far, want to see how much better it can be.
We are paying $4.60/gallon for 91 (with 15% ethanol in it, too) btw, prices went up in the past week. After driving an 18MPG Subaru for the past 5 years, the TSX's mileage is very noticeable in a pleasant way.
Stan
Stan
Does anyone here feel the difference between different brands?
In my case, I see noticeable difference. For some reason, the unknown name XtraMart Fuel given me best mileage as well as good acceleration while Hess is far worse. I've tried Mobile many times and BP few times, they were just average, nothing good, nothing bad. I haven't tried Shell yet, should do.
Btw, in my area, they're all 93 rate.
Oh, okay. That makes a lot of sense.
That's utterly meaningless in respect to this thread. But then again, it also only confirms exactly what I have been saying about octane and motor mapping.
I have maturity and car ownership experience. Language skills thats a great comeback i didnt know we were in an english class.
And by the way you contradicted yourself stating that you get no difference in 91 - 93 then said unless its been tuned for it. So wouldnt that mean that there is a difference between the two? ill let you sit there and figure it out peace
David_Dude
Stan
Stan
BTW let's get along guys.:gheyhug:
No need for comebacks your beyond a waste of my time. I gave my opinion if you don't like it keep your mouth shut and move on
Stan
Stan
