4900 miles and my rear brakes are below 70% life
I have a 2010 TSX which does not qualify for the brake settlement (my VIN number does not apply). It only has 4900 miles and the rear brakes are just below 70% life and the front brakes are just a little above 70%!
Is this normal?
Is this normal?
d0wN sHiFtInG
I have about 6k on my 2010 and not only do i see excessive wear on all 4 pads, but i already feel the brakes aren't as good stopping the car as when they were new. Aftermarket here i come!
I don't know how worn my pads are but they certainly don't stop like it used to. We just might need to re-bed them in again.
My bet is that the tech guestimated the wear based on a quick look at the pads during their standard issue "gazillion" point inspection service
. I would not worry about this report. Look at the fluid level in the reservoir and that is probably a better general indication of your brake pad wear.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Could be a tech trying to get some work? After all, if you need to replace the brakes early, he gets more business. IMO, it's a non-issue for at least 10,000ish miles (probably more). Why fret now?
