4500 mile 5 months short review
Overall I love the car, looks great, has just enough power for normal driving. Here are three things that I don't like, I need to have checked out.
1) Engine pinging @ 2500 rpm (higher octane gas don't change it)
2) Slight shimmy up front when accelerating from a stop from 1st to 2nd gear (hopefully a tire rotation will help, trying to be optimistic here)
3) Just started feeling the brake petal pulsate slightly as if the front rotors are already warped. I only drive this car on Saturday and Sunday and never slam the brakes on.
I don't think Honda ever uses quality brake rotors, I have had 3 Hondas and all of them had very thin rotors, I was hoping the TSX would have better brakes. Maybe I'm not the only one with these issues, comment on here if you do. I already know most have the pinging issue.
I have about the same issues, and then some which I've already said before. I have about 4000 mi and 8 months.
1) Engine pinging
2) No noticeable shimmy, but definitely not as smooth as when it was new.
3) Brake pulses very slightly, same as the tires...not too noticeable but not as smooth as even 1000 mi ago. Brakes just started to squeal last week.
4) Replaced sunroof glass panel for a defective seal.
5) Replaced 5 speakers
1) Engine pinging
I had to have the front door speakers replaced within the first week. I wonder if I have a defective seal on my sunroof also. It looks like the seal sits a little lower than the top of the roof. katmai, did you have a water leak or anything that made you realize this?
What do you mean about the "shimmy"? Can you describe it?
I have the pinging too![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
No problem with the speakers or sunroof yet. Potential very slight brake pulsing, but it could just be bumps on the road (very bumpy roads) that are a lot more noticeable while braking.
The seal was bad because a 4 inch length of the front seal was bulging up about a half inch one day. If you tilted the glass, it would also crease the rubber like it was folded. If the seal is not flat all the way around with the top edge of the glass...if there are uneven bulges anywhere in it, then its defective. The front seal should not crease when the panel is tilted either. If ti does then its bonded wrong and there is nothing you can do to fix it. It can be hidden temporarily with some spray they have and a little pressure, but the unevenness will eventually pop back. The rubber is bonded to the glass and metal structure, so the only fix is a complete panel replacement.
When they put the new panel in, it was centered a lot better. Any leaks I had are non-existent now. Gutters stay clean. It still sits slightly low in the roof, but looking at the adjustment screws, the panel is maxed out so there isn't anything more I can do.
I also told them that sometimes my gas door will not open and my drivers side door I can't get into sometimes!!!! They could not get these things to happen, and I swear today, I couldn't get my drivers side door open
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Isn't that one of the service bulletins? Something about a peg or something that was too big and making it stick some times? If they haven't replaced yours yet, maybe you should ask them about it.
Bummer that they're being unhelpful![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I'm wondering about the "shimmy" - sometimes when I'm accelerating from a stop, the car/steering kind of "wiggles" a little from side to side. Is that what you mean? If so, I'll ask them to rotate tires for me next time I'm in - I only have 1k miles on it, but I guess you never know!
https://acurazine.com/forums/tsx-frequently-asked-questions-125/faq-tsbs-recalls-known-issues-660403/ (that's the thread with the TSBs)
it links to here: http://photos.imageevent.com/astrobo...sb/B08-025.pdf (pdf version of the actual bulletin)
Sorry if I sound like a moron but what exactly do you mean by engine pinging? How would I know what that sounds like? Can it lead to future problems? I'm starting to feel like I hear some type of noise between 2500 and 3000 rpms. Thanks....
Forced Induction
I agree with you these points
I was shocked when my rotors were causing vibrations. I took the car from NYC to ATL, and when I was going over 80MPH I noticed that the tires were vibrating. So it deffinantly needs to have a wheel balance and new rotors. I was pissed cause the car has 8k miles, only driven on weekends.
mada51589
05-03-2022 08:54 PM
