2G TSX Chat, Chit, and General Info Thread
VTEC just kicked in, yo!
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
Itz JDM y0!
^Take me.
hey joeboe, did you vote? #ohio
Hey fellas! Just wanted to update you all that I got my shocks and struts replaced as well as my rotors. But now there is another issue. I purchased new tires, bfgoodrich g force comp 2 a/s to be exact, and I here this like whirring sound coming from the new tires. I hear it when i drive at a slow speed or when coming out of a turn. Here is a video I found of the sound
I dont have run flats and the psi isn't low. I hwve also tried lowering the psi but the sound is still there. I already made an appointment to get it checked out but just wanted to see if you guys knew anything about it. Thanks in advance
why would you lower PSI!?!??! lol a flat tire would cause MORE SOUND!!!!!!
whats your tire pressure currently??
and have you swapped tires from front to rear?
and i didnt listen to the video, but have you considered that the tire just might be a noisy tire????
ROTAREDOM
xtcnrice (11-09-2016)
Received 7,772 Likes
This should be an interesting 4 years in 'murica.
ROTAREDOM
Election wise, no. It was pretty standard as far as elections go. It's the candidates, this time, which made this a no-win circus.
But if you thought the rest of the world hated the USA before, ohhhh doggy, just wait!
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Lol My psi was originally at 37 Front 36 Rear. I lowered then to 34 Front 33 Rear. The thing is that it only does it it when I first start driving. Once it gets going the sound is no longer there.
ROTAREDOM
prolly cause your tires heat up and PSI goes to 40 lol
the phenomenon is commonly called tire flat spotting. kind of flattens out when not driven, then as the tire heats up it will revert back to its shape. and makes sense as a flat or square tire will make noise.
ahhh! that's specifically the tire and its rubber compound.
Unregistered Member
Tire in the video looks like it has a bubble.
ROTAREDOM
Hey plebs, is there going to be any way that us western-folk are gunna be able to tune in to watch Planet Earth 2 this Sunday?
![Captain Obvious](https://acurazine.com/forums/images/smilies/captainobvious.gif)
that video does not correctly display your problem because that tire has a bubble in the sidewall.
unless your tires have bubbles, kinda cannot compare the two.
IF your noise goes away after you've driven it, I believe its flat spotting. google flat spotting to see if that accurately describes your problems
what tire brand and model do you have?
ROTAREDOM
Unregistered Member
Do you mean watch it live as it airs?
answer:![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Use VPN to watch on BBC iplayer after it airs.
answer:
ssjoeboe9 (11-13-2016)
Everyday I'm rofling
I gave you an invite to that torrent site. They'll all be on there.
The following 3 users liked this post by xtcnrice:
ROTAREDOM
Anyone moderating in here????
![Poke](https://acurazine.com/forums/images/smilies/poke.gif)
Are you talking about the bolts that attach to the caliper bracket? Can you clarify?
Is it a part of the knuckle? OEM Acura RL SEDAN 2007 KNUCKLE parts
![](https://cimg9.ibsrv.net/gimg/acurazine.com-vbulletin/720x960/15128768_1143271455748783_719338588_n_431e229ff68add5eafcf1d0d0b9e9e887f76785d.jpg)
Ahhhhhhh... I think you need to go to Brembo directly to get a caliper rebuild kit
xtcnrice (11-21-2016)
Oh yes. Not Brembo's sorry
Try McMaster-Carr?
If you can figure out the size, you can likely find something there. I wonder if @ssjoeboe9 could help with figuring out what grade those bolts are.
Nghi Hoang (11-21-2016)
ROTAREDOM
Try McMaster-Carr?
But upload another picture with arrows pointing to where you need bolts, and post the part number and I will try my best.
Werd Werx (https://www.facebook.com/WerdWerx/) might be another option as well. They appear to be one of the more popular places to goto for getting a set of RL calipers powdercoated (very decent reputation online) and I wouldn't be surprised if they've salvaged some RL calipers themselves and had to get replacement bolts.
edit:
Some more info here http://fatfourcustoms.com/shop/calip...e-upgrade-kit/.
The following 2 users liked this post by xtcnrice:
cu2wagon (11-21-2016),
