2012 transmission fluid filter
Old 10-13-2018, 01:52 PM
Skipswift's Avatar
Is the filter accessible/can it be easily replaced? If yes, does anyone have a part # and link to instructions/DIY video?
Thanks.
Old 10-15-2018, 05:40 PM
SharangCU2's Avatar
I believe the transmission filter on the 2009+ TSXs is built inside the transmission and can't be changed. It's supposed to last the life of the car.
Old 10-15-2018, 05:44 PM
Skipswift's Avatar
That's what I've read to but I've also read that there is an in-line filter that can be replaced by removing the hoses and reconnecting the hoses to the nww filter. Wondering if maybe there is a secondary filter.
Old 10-15-2018, 06:16 PM
Received 8,711 Likes on 6,718 Posts
#3: https://www.oemacuraparts.com/v-2012...e-atf-pipe-6at
Old 10-17-2018, 10:35 AM
t3hhcaptain's Avatar
I've swapped it. It's a real pain getting the hose on the back side off, but it's doable. Basically just disconnect the hoses, take off the old one, install the hoses on the new one.
Old 10-20-2018, 06:15 PM
ImBroke's Avatar
At 107k, figured I'd order one and get this done. Should be able to do it next week.
Old 12-31-2018, 03:11 PM
Skipswift's Avatar
Picture of in-line filter?
Thanks. Any chance you can send a pic of where the filter is located? Can't seem to find it in the engine compartment.
Old 12-31-2018, 03:15 PM
Skipswift's Avatar
TSX part number?
Appears to be a LT part. Do you have a link or part number for the TSX? Want to make sure I am ordering the correct part.
Thanks in advance.
Old 01-08-2019, 09:38 AM
I can try to take one later... but, it's very close to the firewall, and on top of the transmission.
Thanks in advance.
https://www.oemacuraparts.com/v-2009...-atf-pipe-l4-1
Part #4, 25430-PLR-003
Old 01-08-2019, 01:06 PM
Thanks in advance.
Whoops, my bad, was in the wrong subsection, but luckily, both the TSX and Tl share that part number
Old 02-07-2019, 07:16 PM
Skipswift's Avatar
Thanks @t3hhcaptain -- any luck with that photo? Appreciate it!
thefork
08-21-2011 02:15 PM
thelastaspec
06-13-2011 12:59 AM
Putthead
01-13-2011 09:30 AM
silver01cltypes
08-12-2010 03:47 PM
idkjai
08-12-2009 11:16 PM
Quick Reply: 2012 transmission fluid filter
