Wireless Charger In 2021 TLX Does Not Work With iPhone 12
FYI, the latest iPhone 12 is not compatible with wireless charger. So no wireless CarPlay and no wireless charger ![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Have you updated your car's firmware since you've had the car? A new one just rolled out days ago.
This might be a non-issue if you're using CarPlay and "allow" your iPhone to charge over USB.
https://www.youtube.com/watch?v=xvXA...ature=youtu.be
It may be where your phone is on the pad. The guy in this review talks about his 12Pro max moving and it stopped charging.
I just bought a 2021 tlx - type s and was sad that the charging pad function was not great with my iPhone 13. I’m sure it’s similar wit the 12. Has anyone considered that it could not be getting full contact with the pad because of how big the cameras on the phone are and how much they stick out? Has anyone tried a fully flat MagSafe case?
Received 6,470 Likes
Chix, I have an iPhone 12 Pro-I thought the same thing. But in playing around with it, I found that if you place the phone in the middle of the charger (and not against the edge of the charger area, it will work. I've even switched the phone so it faces backwards and it worked!
Try this!!
So I have an iPhone 11 Pro and have had no issues. Apparently the problem is with the new magnet connectors on the back of the iPhone 12 & 13’s.
I was just reading on a Reddit Acura thread that if you turn off optimized changing (it’s on by default) that it will begin charging with no problems on iPhone 12’s and up. Many users in that thread said it began working again.
The following 2 users liked this post by ApexBlue21’:
ELIN (11-11-2021),
oldsnwbrdr (11-13-2021)
AZ Community Team
I am always plugged in for CarPlay but it’s good to know in the off chance I’m not. 😎
Tried it; no luck!
CPR (11-28-2021)
AZ Community Team
I turned off Optimized Charging on my iPhone 12 Pro Max and it still doesn’t work. It comes on when I first lay it on the mat and starts charging, but stops charging after a few seconds, and no, even if the car isn’t moving and there are no vibrations, the phone stops charging.
I bought an adapter for wireless CarPlay and love it but the fact that the pad fails to charge my phone at all means I am going to return the adapter. It’s useless to me if I can’t charge my phone while driving.
Edit: Spoke with my friend at Acura. He said this is a known issue and it’s because of where Apple placed their charging coils. Unfortunately, the only fix would be if Apple moved it on their next phones. Acura used the quality of pads you’d find at Five Below. 🤣 Oh well, guess I’ll stick to wired.
ELIN (05-25-2022)
AZ Community Team
Its not an iOS problem.
Each phone has their charging coil located in a certain spot within their shell. Acura used a very poorly designed pad that hasn’t met specifications for iPhones in a few years now. I have plenty of Qi chargers around my house that work perfectly fine. The only possible fix would be for Acura to issue a fix by replacing the wireless pads with one that has several charging coils so that placement can be met. As it stands this is squarely on Acura.
ELIN (05-30-2022)
As we're all painfully aware the electronic/cellphone is constantly (and quickly) evolving. What is known at the time of design/specification may be obsolete for some applications at the time the new cars are coming off the line. This can be exacerbated by the lack of industry specs and/or even slight differences in technologies employed by android/i-phone designs. Designing applications ahead of the technology is a little like herding kittens. You hope that you get it right... until something unanticipated changes.
Sometimes the "leading edge" morphs into the "bleeding edge"
AZ Community Team
Its usually not as simple as "Its squarely on Acura". Much depends on WHEN the design parameters for the car's systems are locked down... and what was known at that time. This "lock down" happens several months before production of the actual model is even commenced. This is to allow for integration testing as well as ramping up the supply chain (procurement, distribution, stocking, etc, etc) of the components.
My main issue is that Qi isn’t new technology. The necessities of the pad positioning has always been critical and every phone should work on this. The way Acura built the system is very nice but with the enclosure it’s crucial that the coil(s) are placed in a spot that every phone can use.
6G TLX-S
Changes take time and resources. There is always a long list of (big and small) problems waiting in priority to be fix for every products.
Software fixes may come out sooner and more often than hardware fixes.
Unless the problem(s) is safety related or is a deal breaker, otherwise hardware fixes, if available, will only be released in the Mid Model Cycle (MMC) refresh releases.
Jim2301 (05-31-2022)
Perhaps the real issues is the rapid changes in cell phones that provide minimal benefits and yet create these types of issues. They rely on people wanting the newest, that isn't always the greatest or compatible. How is Acura or indeed many other manufacturers supposed to be fully responsible under those conditions. I'm more than happy with my IPhone 11 and deliberately avoid any needless upgrades, for the reasons hashed out on this forum.
I get that. But the iPhone 12 was out prior to the next TLX and also has issues on the new MDX also as far as I’m aware. Acura should have an understanding that not all phones have the coils in the same spot and a charging pad needs to have it placed in a neutral area so all phones can work with it. I’ve seen some home Qi chargers that use as many as 3 coils to ensure all phones work.
Then I exchanged the iPhone 14 Pro for the larger Max size. Game over! It doesn’t even come close to aligning with the car charger. So I’m back to old school wire charging. Just as well, as the useless 2021 TLX doesn’t even have Bluetooth Apple Car Play. Holy crap Acura….keep up with the times!!
HTX2022Aspec (10-21-2022)
I could get my iPhone 12 Pro and even my newer 14 Pro to charge with VERY precise placement of the phone. It was tricky and a pain in the butt for sure, but it could work.
What is what?
If you're talking about the rebooting, often my CarPlay would not be recognized when connecting the USB cable to the TLX. This often happened when you didn't allow the infotainment to properly boot up from a "cold boot" and drove off. To rectify this, you would put the car in Park, shut off the ignition, and open the driver side door to clear the system (I did this a handful of times while stopped at a red light). Restarting the car and allowing the system to fully boot before connecting the wire will then allow CarPlay to work.
To avoid this altogether, always let the infotainment fully boot up before connecting the wire (this includes backing out of a spot that engages the backup camera, like a garage).
What is what?
not sure where rebooting came from. I was posting about the latest iPhones and their inability to line up with the TLX charging pads. The worst being the 14 Pro Max.
Also that the 2021 TLX does not have Bluetooth capability for CarPlay
In my original post, I was basically agreeing with you that Acura should have put wireless CP in the latest gen TLX. Now that I have it on my X3, I can clearly see how stupid easy it is!
oh the charge pad is there, it just can’t line up with the spot in the phone so it’s totally useless now.
Note that all my prior mentions of CP=CarPlay.
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Hihopes (03-07-2023)
When I traded in my dream car (2019 Mustang GT 5.0) I thought I was safely moving to a vehicle that would be top shelf in all aspects. After all this is supposed to be a cut above Honda, the best of the best “Japanese” car.
All i can say now is I hope at least the engine and drivetrain are flawless for years to come, because the bells and whistle’s sure as hell aren’t.
I sort of regret not looking at Genesis, I hear they got it right. I had a Sonata for 11 years, never gave me grief. The things which were supposed to work, worked.
Okay if this logic holds for Acura then one might expect 2023 Integra with wireless charger and wireless carplay to be top priority to have a hardware or software fix for the wireless charge on current iPhones. As new owner of the Integra I can report this is not fixed and BS that an advertised feature is not functional after 5min of charging. It is a fail by Acura and hope that they and provide a resolution seeing this was a KNOWN issue from previous generation Acura and could / should have been fixed before this MMC of Integra.
Very sad that the charging pads have not improved in newer models.
I had more serious ones that had me change out of the TLX w/a full year left on the lease.
