Will These Rims Fit...
Hey, i have a 1999 TL, its lowered with eibach springs and tokico struts. I used to have 18" BSA rims (225/40/18), but they rubbed in the back.. I'm not too sure what the offset on those were. But I can get a good deal on these 19x7.5 Rims, with 225/35/19 tires. These rims have a +42 offset... will they fit without rubbing?
Cyberathlete101
yes...they willl....but u'lll need to cut off a section of d rear bumper approx. 3 inches..very simple dremal will do.....
you can jack up d front all d way up (on either left or d right)....approx. 4ft high u'll be able to c on the opposite side in d rear the wheel tuckin in....n d cause off d rubbin....simply cut the section off....problem solved......
hope that helps......good luck!
hmm, i don't know about that
a 42 offset seems kinda sketch to me, it seems as though it'll keep hitting the fender.
Has anyone actually ever run this set up?
