Will this setup rub?
Old May 16, 2006 | 03:06 PM
Bxscig's Avatar
I was wondering if a set of rims 17x7.5 with 48mm offset mounted with 235/45/17 tires would rub on stock height.
Someone else on this forum has the same rims with the same tire size and rubs once in while with ppl in the backseats but he has a 45mm offset.
What other tire suggestions are there?
Old May 16, 2006 | 03:22 PM
CL Platano's Avatar
Tristate ViP Crew
I don't think so but if anything just get 225's to place it safe..
Old May 16, 2006 | 05:58 PM
optomos's Avatar
I=X - optomos
You could go with a 40 sidewall. 225 40 17
Old May 16, 2006 | 09:15 PM
Bxscig's Avatar
that is about an inch less of sidewall and without a drop that probably wouldnt look good. I had considered but with all the potholes in nyc I would be worried.
Would 225/50/17 have problems ? We could put 225/50/17s on the Type S rims at 6.5" so I thought for an inch more, I would need something with a width of 235.
Old May 17, 2006 | 08:29 AM
paul_huryk's Avatar
Pleasure Unit
A 235-45 tire is closer to the stock tire diameter of the 215-50-17 oem size, but is 20mm (0.8") wider. Actually that is the stock size tire on the 2004-2006 TL.
I think that if you are going to bother with 17" rubber, it makes sense to stuff a 235mm tire under the car - they are about 9% wider than the 215mm.
Rubbing is another story - but there are plenty of people running 235-40-18 rubber and seem not to have major rubbing issues (but some do).
Old May 17, 2006 | 11:34 AM
Bxscig's Avatar
Yeah I wanted to stick with the stock tire diameter as well. Hope the 3mm difference in offset will be good enough to eliminate it the but its only .12"
Old May 18, 2006 | 05:17 AM
Lawaia's Avatar
Moderator Alumnus
You should be just fine. Remember that now all tires are constructed the same; be aware of those that have a squared-off shoulder as these tend to be a bit wider compared to those with a rounded shoulder.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
Tribalheads
Sep 29, 2015 03:24 PM
dirleton
Sep 25, 2015 12:25 AM
