Who has +40 or +42 offset & lowered?
I searched and found many posts, but I need a quick, straight forward answer from someone that has the same setup. I'm contemplating lowering the car about 1.5", but I'm a llittle apprehensive because of my current wheel/tire setup --17 X 17.5" with 215/50 tires, +42 offset. (I would have gone with a higher offset if only I had found this forum before I bought the wheels! )
The rear rubs when I hit a certain type of bump or dip. I cut the plastic tabs and that minimized rubbing, except for when I drive a little fast over a speed bump.
What's your lowering setup for wheels with +40 or +42 offset? What brand springs or coilovers? How many inches lowered? Problems?
Thanks.
Thanks.
I'm lowered on Tein Basics 3.5"f/2.75"r with 18x7.5 +38 offset wheels, 225/40 tires with SPC camber kit all around. I rolled all four fenders and cut tabs out. I never rub anymore when I'm by myself in the car. With 1 or more passengers it rubs a little in the back when I hit a big dip or come off a speed bump too hard. I have almost perfect alignment/toe with the camber kit.
Originally Posted by Mongolian
My simple advice to you is... Don't do it. Find wheels with higher offsets or leave your car alone.
I run a 19x8 with a 40 offset. 225/35/19 Toyos. I have Tein H-Tech springs with a 1.5 inch front drop, and a 1 inch rear drop. A little rubbing in the back, I cut the plastic tabs and its better, but I need to roll my fenders. I love the way mine look.
Originally Posted by RidinDurty
From experience I can tell you that low offset can work on our cars. Aslong as you are willing to do some body work, It can work. You guys are scared shitless of low offsets for some reason
What I don't understand is that you know you have to make fender modifications with low offset wheels and also risk rubbing... so why not just get higher offset wheels? It just amazes me. I think most folks don't want to go through the trouble of making all the little modifications just to make the wheels fit. Hell, if I were you I'd spend the money you are using to roll the fenders, etc. to purchase better wheels that actually fit.
Either way I'm selling my wheels in the next 1-2 months and upgrading to 19" wheels. 19x8.5 +45 offset. Are you happy?
Originally Posted by 02type-s
Like when you are behind a car on the highway, and the wheels are way in, and obviously a very high offset, I think it looks retarted.
EXACTLY. There was a V6 mustang that used to roll around my town that had some Motegi wheels that were pushed in at LEAST 4-5 inches from the fender. I laughed every time I saw that thing. You dont put Motegis on a mustang, as if being a V6 mustang wasnt bad enough!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
