wheel lug question
Tristate Vip Crew
wheel lug question
One of my wheel lugs was cross threaded and snapped inside the lug nut when I was removing it. I am going to replace the wheel lug myself. Is there anything I should look out for, it seems to be a pretty straight forward install. Thanks
Dragging knees in
Be aware that in order to "properly" install the lug, you will have to take out the wheel bearing assembly out of the hub.
Otherwise, do what I did. After taking off the caliper and the rotor, I turned it to where there was just enough room on the hub to slide the lug by. It will not go straight in, so you will have to tap it in with a hammer, then tap it. At least that's what I did, because I didn't want to take out the wheel bearing assembly, since I didn't have a hydraulic press to push it back in.
Good luck.
Good luck.
Tristate Vip Crew
Good luck.
Good luck.
Tristate Vip Crew
Thanks again everyone for your help, all this info is going to be very helpful. I went to my local dealer and they want 6 bucks for the lug I found it online for 2 bucks!
nanos
11-12-2015 08:41 PM
