Want to lower
Want to lower
Right now i have stock suspension on my TL. I wanted to drop it not too low, but just right. My vibe from doing a little of research would be to go with the H&R Sport Springs 1.75 front 1.5 rear.
Now my question is if i were to buy those, how would i get them installed? I glanced through the DIY and thought it looked complicated as hell. (keep in mind i'm no car expert )
Also, what do those springs go for about? And if i were to get a shop to install them for me how much do you guys think that would be??
B A N N E D
in essence you are just replacing the factory springs just with ones that are a little shorter,
but anyways by the way it sounds is that you have not done an alot of diy, so it might be easier just to let a shop do it, especially considering the stock springs are still under quite a bit of tension (especially fronts) even when the shocks are fully extended, even the new ones will have tension on them once installed with the shock fully extended
also this would be the time to also do your shocks while they are already out
Following the DIY changing springs is actually pretty easy. Just take your time and every thing will be ok. Plus you get the satisfaction of knowing you did it.
Ok well i found the springs here: http://store.excelerateperformance.c.../i-238959.aspx
As for shocks, is it a priority i get new ones? What am i risking if i dont? And are Koni shocks a good choice?
Koni yellows are one of if not the best along with Bilstien
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
