Tire Size
Tire Size
If I upgrade to a 17 x 7 wheel for my 2000 TL, what size tire do I need to look at to stay with the same diameter as the stock 16 x 6.5?
Thanks. I think I have finally figured out the numbers. If I figured correctly, the 225/45/17 is going to be around 3/4" shorter than the OEM and the 215/50/17 will be only about 7/32 shorter. If I go with a 225/50/17, that would be around 3/16 taller. How much difference can there be without affecting the speedometer? And do my figures sound correct. Again, thanks for the help.
Comptech Freak
215/50/17 or 235/45/17 are the closest you can get
i recommend 215/50/17 because it has more than enough grip on our car with that setup and best fuel economy
that's what i have with my 17x7 wheel
Comptech Freak
Originally Posted by AcuraX2
The Falken ZE-512 in 215/50/17 is the one I am looking at with packages from tires.com. Thanks for the help.
if you want more performance on the all season, Falken ZE-512 or Sumitomo HTR+ is way to go
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
