Rubbin On 20's
Old 09-16-2005, 07:47 AM
TLONTWENKIES's Avatar
Rubbin On 20's
Put 20's On Only Rub When Rear End Bounces. Wondering If A Koni Shock Would Fix This? Or Diffrent Springs?
Old 09-16-2005, 12:46 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Probably not. 20s are a big tire for the TL. what offset are you running, cause if its wrong nothing you do will keep it from rubbing
Old 09-17-2005, 07:36 AM
Rims Are 20 X 7.5 With 40 Offset..took It To A Body Shop Yesterday The Claim Rolling The Fenders Will Make Clearance After The Took A Look @ It. I Also Read A Forum About Someone Putting A Inch Longer Spring In Rear. Ever Heard Of This Or Where You Buy Something Like That?
Old 09-17-2005, 09:52 AM
derrick's Avatar
Whoever sold you those rims don't know very much about the 2nd gen TL. 7.5" rim with +40 offset?! The car comes from the factory with a 6.5" rim with +55 offset. Not only are your new rims wider, the offset is WAY lower.
If you go with a taller shock, your car is going to look like a real 4x4. Then you might have issues with camber (toe OUT). Dude ... I think your setup can't be easily fixed. I seriously doubt cutting tabs + rolling fenders is gonna help in your case. If you combed this part of the site and did a search ... very few people have done 20s 'cause of the offset issue (ie no rim manufacturer makes rims with such a high offset without it being custom).
Can you bring back to where you bought them and go with a different setup? If you're gonna go with a 7.5" rim, you'd best to get something with at least +45 offset or more (ie higher, the better)
Good luck.
Old 09-17-2005, 08:20 PM
Peach Tea
badazzTL's Avatar
Wow 20s are too big for the TL. I bet ur car looks like a 4X4. Big ass wheels.
Old 09-17-2005, 09:54 PM
Mongolian's Avatar
should've gone with a truck....
Old 09-18-2005, 09:49 AM
Peach Tea
badazzTL's Avatar
Or an Impala.
murph145
3G TL Photograph Gallery
52
04-20-2011 12:36 PM
617acura
03-11-2011 03:05 PM
Papayon
09-13-2009 08:11 PM
PitBull_TL
15
08-09-2007 01:51 AM
Ac-right
05-08-2007 11:16 PM
Quick Reply: Rubbin On 20's
