Rolling fenders?????
Missing my Acura's
Well i just got my wheels, And i put them on they are rubbing when turning and on bumps. I drove about 1-2 miles and you could see where they were rubbing so i took them off. Now what im wondering is did i waste my money, Will i have to raise it or can I roll or cut away the fender to fix this problem and is it worth it ? any input will help!
odds are you got the wrong offset. you need atleast a +45 +47 to +50 being ideal
Missing my Acura's
Originally Posted by REDLINEN
how can i check this? I got them off this sites blackmarket.
Originally Posted by @cUr@-TL
well he's lowered 3" so he would prolly rub even if the offset was around 50...
you're prolly gonna have to roll the fenders.
In Pursuit of Perfection
if your rear is rubbing out the outside of the tires, rolling your fenders may fix it, it fixed mine. your offset could also be off or the tire size might be too big. i dont recommend any more than a 45 height on the tires if your ride is dropped. about the front, if the tires are rubbing when you turn its a hard problem to fix. if you have money i would buy new wheels with correct size tires. if you cant afford that i would pull out the wheel and see if you can tell where the tire rubs. if it rubs at different areas of the wheel well you can try to shave it cut out that area. you will get your engine dirty but it solves the problems. the front of our cars dont really have a fender to roll. the rears have a slight tab you can bend back. but the front wheel wells attach straight to fender so theres not much you can move back. when rolling the fenders do it slowly so you wont crack your paint.
do it yourself... take a baseball bat... stick it between the tire and the fender, and bend downwards... the bat shoudl become perpendicular to the ground and should bend the fender in... DONT KNOW HOW THIS is gona work on this car but i did it on my last car and it workd fine... i duno about acura's...
Missing my Acura's
Well i had the fenders rolled , and the rear bumper taps shaved and it fixed the rear rubbing but now it looks like im gonna have to cut away the plastic in the front fenders a lil but hey fuck it! other than that the ride looks great and ill have pics soon thanks for all the help!
DerrickW
11-15-2015 05:52 PM
09-25-2015 06:14 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
