rims help
rims help
hey people i want to kno for my tl 03 s i want to get these rims it says 17x 7.5 now i kno the size is 17 and the i dont know what the 7.5 is lol but i want to kno if this well fit? on my car or well they be problems or not ...another thing i allso want another pair but they only come in 18s so well this fit aslong as they are 5 lug and well it cause trainy problems or well it be a horrible ride if i get the 18s ? thanks to all the help and sorry if this is dum or not
Avant Garde Wheels
everything you need to know was stickied in this sub-forum...
VERY first post..
https://acurazine.com/forums/showthr...93#post8392993
VERY first post..
All,
When purchasing rims for a car, there are several specifications to ensure a good 'fit' (ie no need to do any fender mods).
1) rim size
2) rim width
3) offset
4) bolt pattern
Rims range from 16" to 19" for our cars. Any smaller and they won't clear the OEM calipers. Any larger and you will have issues with 'rubbing'. I'm sure someone will say, "I got [XX] size to fit", but seriously -- look at their setup and most will not find that look very appealing.
Rim width and offset go hand-in-hand. Depending on your rim width, you have to watch the offset. The wider the rim, the higher the offset (so it doesn't rub up against the wheel well or plastic tabs of the fender when you hit a bump).
Our TL/TLS come with 6.5" rims with +55 offset, made my Enkei. General rule (but not always the case since there is some variation among manufacturers):
7" rim = +42 offset
7.5" rim = +45 offset
8" rim = +48 offset
> 8.5" rim ... forget it unless you wanna do some custom bodywork for it to fit.
This is only a guideline, not an end-all, be-all. Those who have done suspension work may have to find a higher offset than that posted to make sure their application will not have any problems.
Lastly, bolt pattern -- our cars have 5x114.3JJ bolt pattern. Luckily, many rim manufacturers make this bolt pattern but offset will be your limiting factor.
1) rim size
2) rim width
3) offset
4) bolt pattern
7" rim = +42 offset
8" rim = +48 offset
