Rear struts maybe???
After the last couple alignment jobs, I've noticed my passenger rear camber has been slightly out of spec: -1.3 to be exact (with a -0.5 to 0.5 range). Didn't really pay much attention to this, however, I was recently told that my rear strut is starting to weaken a bit causing the camber reading to be where it is. Everything is stock, original. 155,000 miles on the rear struts. Is it recommended to replace these? Will it bring the camber specs back within range? I was told before that teh rear struts on Honda/Acuras generally last the life of the car.
personally i would replace them. they might even be bent for all you know, causing the issue.
SSTS
Originally Posted by SatinSilverTypS
the only struts i've ever seen last that long with no issues are on a 1996 nissan 300zx twin turbo with 170k miles on the suspension that my friend owns. i don't know what kind of luck everyone else here has had though with their cars. my car had comptech springs when i bought it so i don't really have any points for comparison.
SSTS
SSTS
Originally Posted by fsttyms1
mine made it to 170k or so and they still wernt that bad of shape. I dont know how the strut has any thing to do with the camber unless its sitting lower on that side
the strut wont fix camber if its not sitting lower. our cars you cant adjust camber on, you need camber kits to do that. The strut does nothing more than attach to the car and lower control arm. it cant control/ adjust camber.
Thanks for your responses. I kinda knew that the camber was unadjustable, for some reason this "mechanic" seemed to think that a strut would correct the negative spec (and wanted to do the job to collect extra money that day). So now I know that unless I get some form of kit installed then my camber results will remain the same. In light of that, I will probably just leave things as is on this matter. Is there a maximum out of range spec I should keep my eye out for? Right now it is barely outta spec at -1.3. Thanks again!
acurajj
02-14-2016 02:28 PM
oyayjoe
09-12-2015 04:40 PM
