Questions on the wheel Lowenhart
1. Does anyone know what size of lowenhart rim songoku used?
2. How do you like those rims?
![](http://www.acurainspired.com/gallery/data/17e62166fc8586dfa4d1bc0e1742c08b/495_p17304.jpg)
![](http://www.acurainspired.com/gallery/data/17e62166fc8586dfa4d1bc0e1742c08b/495_p17307.jpg)
more pictures at http://www.acurainspired.com/gallery...id=495&uuid=43
I found a set but it's 19X8.5 45 offset.
3. Will I have any problem if those rims go on a 2002 Acura TL?
Thanks in advance.
Thanks in advance.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![](http://www.acurainspired.com/gallery/data/17e62166fc8586dfa4d1bc0e1742c08b/495_p17309.jpg)
thanks for all the comments...
I am not quite sure about the style but I am going to mold my OEM front and WW rear lip kit on the bumpers so they will look like one piece.
Actually the other thing that I am worrying about is that for a 8.5 wheel, I was told that I should get a 225 tire instead of 235 because of the rubbing issue. Is 225 on a 8.5 rim too stretch? Also my car now is on Tein S.S coilover, if I am really going to get this set of wheels, I need to raise up my car a bit to 2 finger gaps in order to avoid the rubbing issue. Is that correct?
Thanks again.
Thanks again.
bro..my car is dropped..and im running 8.5 in wide wheels with a 43 offset and they do not rub at all..im running 18's tho..but you have to remember i have a 40 sereies tire..with 19's you will be running a 35 series which is the same height as my 18's..im have 225 up front 235 in the back[got a good deal on the 235 and needed 2 tires asap]you 'll be fine with the 225
-Arsenic-
Thanks again.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Thanks again.
Moderator Alumnus
DiamondJoeQuimby
09-10-2015 11:40 AM
