Question about Rubbing
Old Feb 15, 2005 | 05:26 PM
vmaxer's Avatar
I put 17s on my TL with slightly wider tread. They ain't the biggest but the DC roads are horrible (hence the reason why I had to buy rims in the first place). Anyhow, whenever I have people in the backseat the rear tires rub during any bump/sharp turn.
Is the solution the suspension, or did my shop screw up the install? I didn't think rubbing would happen with just 17s.
Old Feb 16, 2005 | 03:13 AM
Lawaia's Avatar
Moderator Alumnus
It's not the diameter of the wheel that is causing you to rub. It's the width and offset that will determine proper fitment. What are the specs on your 17" wheels?
Old Feb 16, 2005 | 01:52 PM
vmaxer's Avatar
rims are motegi MR7. From their website:
PN 2076-7717 17x7 +40 5 1/2 5x100 & 5x4.5 25.5 lbs
I believe the tire is rubbing against the plastic edge of bumper or metal lip of fender. So maybe the wheels sit too far out?
Old Feb 16, 2005 | 01:53 PM
vmaxer's Avatar
I believe the tires are 215 or 205.
Old Feb 17, 2005 | 03:16 AM
Lawaia's Avatar
Moderator Alumnus
+40 offset is way too low. Best bet is to sell those wheels and get some with a higher offset.
Old Feb 22, 2005 | 07:43 PM
vmaxer's Avatar
what is the correct range for the offset? And could you recommend tire/rim combo sizes in 17/18? I got 17s because of the potholes around DC but i really want some 18s.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
navtool.com
Sep 25, 2015 05:15 PM
