Possible to correct toe?
Originally Posted by phipark
Is it? My alignment spec sheet says I'm out of spec in toe on all four wheels. Can I get it fixed?
yup, from what ive seen, when the car is on the alignment rack, the monitor shows the tech what wheel and how much it needs to be adjusted, and they adjust it.
Not Asian
Originally Posted by derrick
Toe is extremely important to adjust properly. It will eat your tires out quickly if its off!
I guess the shop never corrected the toe then.
Yeah, learning the hard way.
So what did the shop do, put it up on the rack, set the sensors on the wheels, and print out your current alignment specs? If thats the case, you shouldve had them set the alignments to spec.
ITSJESTER
17
12-06-2018 02:29 AM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
guyvelella
09-30-2015 11:02 PM
