Offset 55 mm vs. 45 mm
hi there.
i drive tl-s 2003 , and now im trying to get new wheels and tires "215 45 17" 17x7 with an offset of +45mm
do you think ill have any problems , or its gonna be smooth ride.
thanks
thanks
Hey Trance, nice to see a fellow noVA TLer. I don't think you should have any problems at all. I had a similar setup last year before I purchased my 18's and I had no problems at all. But the only difference was that I was running a stock tire setup 215/50/17. Keep in mind also that I was also lowered on H&R sport springs. The only thing that you might consider is that your speedometer will be slightly off, but not by much. BTW we are having a local meet this Saturday, Jan 28, 2006 at Tyson's Corner Mall. You might want to drop by and pick up a few tips from the local crew. Here is where you can find information on the meet: https://acurazine.com/forums/acurazine-clubs-meets-15/mini-meet-hang-out-time-md-dc-va-pa-feb-4-2006-a-327647/
Originally Posted by JPTL-S
Hey Trance, nice to see a fellow noVA TLer. I don't think you should have any problems at all. I had a similar setup last year before I purchased my 18's and I had no problems at all. But the only difference was that I was running a stock tire setup 215/50/17. Keep in mind also that I was also lowered on H&R sport springs. The only thing that you might consider is that your speedometer will be slightly off, but not by much. BTW we are having a local meet this Saturday, Jan 28, 2006 at Tyson's Corner Mall. You might want to drop by and pick up a few tips from the local crew. Here is where you can find information on the meet: https://acurazine.com/forums/showthread.php?t=327647
The post say's it is for February 4th????
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
which one is it? I can't make January 28th but I can make the 4th
Sorry for the confusion bro, I stand corrected it is Feb 4, 2006
Please keep discussion on-topic.
You can use PM to send invites to meets.
As for your rim question, TLKrazey20 -- 17x7 with +45offset should be OK if you don't slam it to the ground. OEM CL-S rims are 17x7 (but +55 offset). +45 offset is a full 1cm (0.4 inches) your rims will 'stick out' compared to OEM rims.
Tires ... 215/45/17 ... NOT a good idea ... that's > 3.3% smaller in circumference than OEM (215/50/17) setup. Why not go 225/45/17 or 225/50/17 ... both are < 2% difference than OEM spec. What tires are you looking for?
If it's a rim/tire complete set you're getting, then I would pass. If you like the rims -- fine -- see if the guy will just sell the rims but get different tires. Your ABS / traction control / speedo / etc might not respond appropriately due to the > 3% change in tire circumference.
I already bought it , its a complete set . at first i thought it was the same offset . found out later its not.
So i dont think its a good idea to put them on , right
thanks for the help
thanks for the help
thanks for the help
thanks for the help
![](https://img224.imageshack.us/img224/8537/tirecomparison2ep.jpg)
As long as all 4 tires are the same size the only real thing it will do is throw off the spedo by a small amount. It wont cause any thing to work differently, It will just work at a speed that s not accurate
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
