Normal Drop?
Old Jun 26, 2009 | 07:18 AM
getpaper450's Avatar
Normal Drop?
So i just put on some h&r sport springs and the right side of the car is sitting a little higher then the left side and i dont know if this is normal, on the right side i can fit three fingers but on the left i can fit three but its just a bit tighter anyone kno if this is normal?? is it just because both sides can never be exactly equal? thanks for help
Old Jun 26, 2009 | 08:40 AM
bonknhead's Avatar
That doesn't sound right. I've got just under two fingers at all four corners with my H&R Sport springs. Who did the install, and are you talking about the front and rear on the right being at 3 fingers?
Old Jun 26, 2009 | 09:37 AM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
HMMMM....sounds like you have new springs...give them about 2 weeks or so to settle then go and see if you need an alignment...if they arent new then "HOUSTON YOU HAVE A PROBLEM"...
Old Jun 26, 2009 | 12:50 PM
The 3 finger space was for the front tires...Was I supposed to compress the new springs all the way before I installed them?Also,I didn't trim anything and I haven't done a wheel alignment yet,wat do you think the problem could be other than letting it sit for 2 weeks?
Old Jun 26, 2009 | 01:09 PM
ZEUS'O3TL's Avatar
before you took the old springs out did you mark the top of the strut and lug with chalk or something to make sure you line them up correctly with the new springs?
Old Jun 26, 2009 | 02:40 PM
I had them installed at the shop,they just took off the old springs off the shox and put the new ones on...
Old Jun 26, 2009 | 03:54 PM
ZEUS'O3TL's Avatar
i would go back and let them know about it asap and let them know that u will be back in 2 weeks when the springs settle to see if antyhing changes...jus to cover urself...
Old Jun 26, 2009 | 05:24 PM
twistedwedge's Avatar
6MT Someday..
^^^ Make sure to cover your ass
Old Jun 26, 2009 | 06:51 PM
does this look weird passenger side supose to be higher
drivers side
passenger side
Old Jun 26, 2009 | 06:52 PM
jjashaa's Avatar
Avant Garde Wheels
let the springs settle.. transmission is on driver side.. so that could be a possibility.
Old Jun 26, 2009 | 07:33 PM
mrchan625's Avatar
like others have said let the springs settle and see how it is after about 2week or so, also the driver side of the car is going to be heavier..so that might be another reason
Old Jun 27, 2009 | 10:38 AM
6MT Someday..
mine sits the same all around...since day 1..dropped on eibachs
Old Jun 27, 2009 | 12:08 PM
thinhthan's Avatar
yea mines was like that to
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
