Need new tires, will raising my car help treadwear?
I put new Nankang tires on the front of my car about 10,000 miles ago and one side already needs to be replaced. The inside is worn down. I've got tein coilovers on and the car is pretty low. I don't have a camber kit and I didn't get an alignment done. I plan on replacing all 4 tires in about a month with either conctiextremes or kumho asx. I'm going to get an alignment this time and I wanted to know if raising my car about an inch would keep the insides of my tires from wearing so quickly. Also if there's any suggestion on different tires or a place to get tires that would be cool too.
-Matt
-Matt
No, but Getting An Alignment will! Would have saved your tires from having to be replaced
-Arsenic-
-Matt
-Matt
LOL you just answered your own question. You should have known you were gonna waste those tires, I'm actually suprised they lasted as long as they did.
Yeh, honestly I didn't know that alignments were that important. I only had the car about a month before I replaced the front tires -- didn't know the characteristics of the car yet. I figured that if the car went down the road and didn't pull too much to either side i was in the clear. Pretty dumb on my part I guess. So raising the car about an ince wouldnt help at all? Anyone know of any places where u can pay one price and get lifetime alignments and/or tire rotations? they're so damn expensive.
And thats part of owning a car, they arent cheap to own and maintain but if done properly the car and its parts will last a long long time.
You should have an alignment done every year.
I'm definitely getting it alligned, I just wanna know if I raise it a little would it help prevent tire wear even more?
6G TLX-S
The TL has a very limited range of adjustment for camber angles. If the drop is too extremely, even an alignment job will not able to move the camber angle to within spec. In that case, a camber kit is needed.
The gen2 TL has no camber adjustment front or rear, toe adjustment only
Thats why a threaded rear control arm is installed- so you can adjust the rear camber
The rears really seem to need it if you go over 2 inch drop
If the insides of the tires wore out- there is your answer
A front camber kit replaces the ball joints with a trick adjustment plate on the new ones
Track day people will use this more than any street driver
Always align after suspension work of any kind!
Tires are expensive
Tires are expensive
Buying the right tires improves lifespan too- yours and the tires
-Matt
-Matt
I went with the continental contiextreme contact. I read some good reviews and hear that they're pretty good in the snow which helped my decision a lot. I'll be getting all 4 installed plus an alignment for $507 at Mavis. I thought it was a pretty good deal.
I'm not sure how much it's lowered. The back may be all the way down and the front maybe it could go an inch lower. Not quite sure. The back tires don't seem to be wearing quickly at all. I thought when I first bought the car that I'd need to replace the backs first but they haven't worn too prematurely. I'll try doing the rotate and flip with this set of tires depending on how expensive it is to do that. Seems like this place charges 30-35 to mount tires if u haven't bought new ones from them. If I do that, I'm 1/4 of the way to a whole new set of tires anyways so I'll see what kind of deal I can get.
I need 2 more gears
As far as tires go I'd recommend contiextreme's too. I've had them on my car for a good 20k now and the treadwear is great, still tons of rubber left. I can also vouch that they handle very well in the snow for a tire that grips so well on wet and dry pavement. They are the best value IMO. Get an alignment when you get new tires and make sure you tell them that you want the facts and not just a piece of paper and a goodbye.
$70 to reverse in my area...
Mine is too low for camber kit...camber kit will push the top of tire out and will create rub. Noone in my area is willing/able to do a fender roll. Even within spec, just barely, I get uneven wear, more on the inside 1/3 of tread. Alignment done, rotation done, air pressure checked, etc...when lowered I just don't get as much wear as stock Just The price of lookin good!!
