need help!!
VIP TL
need help!!
I'm trying to adjust my F2 type ones for the first time since I've installed them. First off the wrenches always slip off its retarded. Second off, maybe I'm not doing it right, how do I adjust my fronts? Do I use both wrenches or what? TIA!
I'm a thrill seeker in my
You need to have the entire end of the car you're adjusting off the ground and no load on the suspension when adjusting your coils. Ideally you should be suppressing the spring to take some of the load off the strut collars as well. I've had my Teins on the same height for the past 3 years now (including winters) so I'm pretty sure I'm past the point of ever being able to adjust them again.
VIP TL
just to be sure, i just loosen the bottom collar and turn the bottom shock body to adjust the fronts, right? and just to be safe, what do i do on the rear? i forget what they look like lol
VIP TL
ya thats similar to mine, but not the same for the fronts but i figured it would work, i watched that yesterday.
the function and form website is down and all the info and vids there so that sucks.
