Moog Endlinks
Hey i just got moog endlinks in the mail, rsb on the way, I know that the nipples are self tapping but do I need to add grease to the back first (if so what kind how much) and can i just thread the nipples in at anytime, or is there an order.
Screw all 4 grease fitting nipples into the 2 end links.
Install both end links on the car and properly tighten everything down.
The end links should be pretty much full of grease already, but if your worried about it, hit each grease fitting with just a short, small stroke from your grease gun. STOP as soon as you see the tinyest bit of grease coming out from around the rubber seal. Wipe clean with a rag. Then enjoy your improved end links.
Those Moog end links along with some polyurthetane sway bar bushings makes for a nice, easy, and noticable handling and ride upgrade.
Jul 16, 2017 07:33 AM
adreano17
Sep 29, 2015 08:48 AM
