Moog Endlinks
Old Sep 7, 2011 | 02:54 PM
2gTltypeS's Avatar
Question Moog Endlinks
Hey i just got moog endlinks in the mail, rsb on the way, I know that the nipples are self tapping but do I need to add grease to the back first (if so what kind how much) and can i just thread the nipples in at anytime, or is there an order.
Old Sep 7, 2011 | 05:09 PM
fsttyms1's Avatar
mine came with the grease fittings, and no they didnt need to be greased first.
Old Sep 8, 2011 | 12:41 PM
2gTltypeS's Avatar
To clearify your endlinks came with the Grease fittings already threaded into the back? And thanks i appreciate it
Old Sep 8, 2011 | 01:01 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Screw all 4 grease fitting nipples into the 2 end links.
Install both end links on the car and properly tighten everything down.
The end links should be pretty much full of grease already, but if your worried about it, hit each grease fitting with just a short, small stroke from your grease gun. STOP as soon as you see the tinyest bit of grease coming out from around the rubber seal. Wipe clean with a rag. Then enjoy your improved end links.
Those Moog end links along with some polyurthetane sway bar bushings makes for a nice, easy, and noticable handling and ride upgrade.
Old Sep 8, 2011 | 06:50 PM
fsttyms1's Avatar
Yes, mine came with the fittings.
And please buy a front sway bar as well. It will help your handling even more so and make the car handle better
Old Sep 8, 2011 | 08:25 PM
2gTltypeS's Avatar
Any recommendations for the front sway bar i mean clearly i am trying to beef them up, a progress rsb is in the mail any bars a good compliment?
Jul 16, 2017 07:33 AM
Onyxthecat
Oct 18, 2016 02:05 PM
adreano17
Sep 29, 2015 08:48 AM
Brandle34
Sep 23, 2015 07:20 PM
