Light Weight Rims Wheels
There is a slight performance advantage, depending on how much weight you're actually saving per wheel. Also, since the car has to move less weight, there is a possibility of fuel savings as well.
Light weight wheels have less mass (unsprung weight) and therefore less motion of inertia. They will spin up faster, and as a result, better throttle response. In addition, less unsprung weight means the suspension can react faster, and thus better handling performance.
The only problem with light weight wheels is that they are almost always very expensive.
Originally Posted by DC3328
does anyone know how much the oem wheels weigh? and is there a difference between 17's that weigh 25 pounds and 19's that weigh 25 pounds?
Ultimately, it's the total weight of the wheel/tire combo that counts.
As a general rule, for wheels of the same manufacturing process, the bigger the wheels, the heavier the wheel weight. But for some expensive light-weight forged wheels, even 19" size is lighter than the conventional cast wheels of 16" size.
Originally Posted by WillrunifChased
I want some Dymag wheels with the carbon fiber barrel and the hollow titanium spokes.
Dymags have the carbon fiber wheel with forged magnesium spokes.
Originally Posted by fsttyms1
Also where that weight is placed makes a difference. Closer to the hub the better (usually happens with smaller wheels)
So the lesson learned is that always check the tire weight when shopping for tires, and buy only light weight tires.
I'm glad that I bought the 23 lbs Michelin Pilot PA3 instead of the 29 lbs Dunlop M3 for my snow tires last season, despite forum members kept telling me how good the M3's were. The M3's are heavy like hell.
