Lexus IS wheels?
the TL hub bore is 64.1mm and I think the Camry has around 60mm, so machining may be needed. But, find out for sure what the hub bore is of the Lex IS and if it is bigger than ours, you may be able to find a hub centric ring to match it up to our cars without machining..if the lex's are smaller than 64.1, a machine shop could certainly do it if they know what they hell they are doing
^^ i used camry as an example, but on ClubLexus forum, there are plenty of references to the IS having a 60.1mm hub bore. I would call DiscountTireDirect.com cust svc # to confirm the hub bore size to be sure. 800-589-6789 They sell hub centric rings and i bought a set or two from them before for aftermarket wheels.
JByron
Jan 8, 2016 09:49 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
