Just Got a Wheel Alignment - specs and question.
Old Apr 19, 2006 | 09:30 PM
big mike 13's Avatar
i finally got an alignment after over a year of being dropped.. lol
i dont know what any of these numbers mean, so can someone help me out?
should i notice a big difference now?
and is my front bad enoguh to spend $200 + install and another alignment for?
thanks
Old Apr 19, 2006 | 10:26 PM
optomos's Avatar
I=X - optomos
Negative camber is good, but im not so sure about over 1 degree of negative camber being good. What kind of drop do you have?
Old Apr 19, 2006 | 10:42 PM
fahoumh's Avatar
Shogun Assassin
They did a pretty good job eliminating rear camber and front toe. I've been told there is no stock front camber setups on our cars so if you wanted to get rid of that front camber you'd need a front camber kit.
EDIT: here's a site that explains camber, caster, toe, etc: http://www.ozebiz.com.au/racetech/theory/align.html
Old Apr 19, 2006 | 10:49 PM
well i installed a rear camber kit, the reason for the rear being corrected... which i also got a good deal on ($80) and i didnt feel like dropping $200+ for hte ingalls arms...
im dropped on tein basics... no finger gaps
Old Apr 20, 2006 | 01:07 AM
optomos's Avatar
I=X - optomos
You can get a set of fronts for 130-140. Not bad on the front considering the drop you have. You actually helped figure out what ill need for my drop now!
Old Apr 24, 2006 | 10:02 PM
mackntheacc's Avatar
my girly girl
how much should a wheel alignment be about? i live near garden city so when i need my alignment do you give the shop good a review?
Old Apr 25, 2006 | 09:47 AM
fsttyms1's Avatar
The key is you got rid of the half deg of toe. That would have killed your tires in no time. 1.7 is still pretty sharp, and you may want to look into a camber kit for it.
Old Apr 25, 2006 | 05:49 PM
well i got it done with my rear camber install... total was $120..
i think it should be $60-80 for the alignment alone.. and yea, i would recommend them.. nice people.
Zonian22
Nov 14, 2015 01:20 PM
acurajj
Sep 19, 2015 03:47 PM
GhostTL09
Sep 19, 2015 01:57 PM
nuldabz
Sep 3, 2015 05:49 PM
Zonian22
Sep 2, 2015 08:19 AM
