installing new suspension
Does anyone have instructions on how to install new springs/struts on 02 TL. How difficult is it? Someone told me I need a spring compressor to do it???
Any help is greatly appreciated. BW
2003 TL-S A-SPEC
if you've done it before, its pretty straight forward. If not get someone to help you.
If you're asking about the spring compressor then i would definitely recommend seeking help.
DIY Lowering Springs
https://acurazine.com/forums/ramblings-12/shelf-life-whisky-164323/
It's not that hard. Just some bolts and muscle. The first 2 might take you 3 hours or so, but the next two will be much easier. Yes, you "need" a spring compressor. You can rent one at AutoZone with a ~$40 deposit. You get that back when you bring the spring compressor back. Don't point the springs/compressor/strut at your face, other people, or your car... When we did my Tein springs we didn't use a spring compressor but rather used the 2-tires+wrench+crossing fingers method. Exciting, but not recommended.
T-Swzy
get 2 spring compressors if you plan on keeping the old top hats. 1 compressor to remove the hat while the other puts spring on the strut.
we did a friend's car with just one and i can tell you straight up we spent more time compressing springs than anything
If you are not sure how to use a tool in a very dangerous job, simply drop the old suspension and take in buddies car to a shop-
who will glady and safely swap the springs and hats over for you-
about 10 bucks per would be rightous price for you not spending the rest of the day in the Emergency room
As Fsttyms says- the loaner tool uses 2 seperate compressing units, one for each side of the spring. A shop has a big version where its all one unit and run by an air wrench.
Any other method CAN result in severe injury
You and a friend can remove all the strut assemblies, then take it to a pro for the parts swap over, and you put them back in.
Call a few private honda/acura shops and ask them for a price on each way
Figure 3 hours labor approx
BoricuaTL
04-08-2016 01:08 PM
MrHeeltoe
79
10-14-2015 08:47 AM
nuldabz
09-03-2015 05:49 PM
