installed tanabe springs/tokico blue struts
Mods - can move this if you want but not many people go to the tire/suspension section and I thought people would like to hear about my setup.
anyway, I used to have the old (gray) Comptech springs with stock struts. It was ok but the springs were rusting to hell and the struts were getting old (97k miles).
I used the instructions from the CL site, and they were very good. I would say it took me and my father in law about 3.5 hours to get it done. We had one set back, and without that, we could have done it all in less than 3 hours for sure.
I dont know of anyone with Tanabe springs, but I am VERY happy with them. I got the NF210 springs. They are supposed to be close to stock feel but still lower with some more firmness. http://www.tanabe-usa.com/springs/
I like them because they are about the same lowering as the older Comptech springs but slightly smoother, and along with the Tokico blue struts, the car feels like new. It takes bumps so much better and waves in the highway are absorbed naturally. My old setup just felt wrong with some bumps. It would be way to stiff or not near stiff enough sometimes and I would nearly bottom out way to easily. I also had some "clunk" noise from the right rear spring area, and that is gone now.
I think the tokico struts are a very good replacement of stock ones if someone is lowered slightly or not at all. I didnt get the Illuminas because I knew I wouldnt ever care about adjusting them and the blues feel just right anyway.
I will try to post pictures if anyone wants (the springs havent settled yet though).
my illuminas will arrive tomorrow....so excited! ima bring my ride up to Dodgers Stadium early morning to test it out after the install! never realized power sliding ya car would b so fun after i drove my buddie's SI up at Dodgers! lol....i almost roll down the hill on my first try!
2 sets sittin quietly, Eibach Pro/H&R!
Originally Posted by phipark
I believe the main difference in ride quality is the Tokico HPs. I have them with Tein H-techs.
ou, that sounds sweet. Post some pics. I have a clunk from my right rear area as well... ah, the trunk of the car to be specific...
I was thinking about asking y'all if that was common. I plan to tell the dealer about it at the next oil change. There's also a clunk in front that may be a motor mount.
I haven't put my stereo from my 99 in my 02 yet. My 99 sat a little low in back with the sub and amps. Is it possible to get a slightly, 1" maybe, higher rear spring?
you can always check your sway bar bolts - the end links specifically. They should be very tight - I was going to take off my front sway to install the struts, but I didnt need too and I backed the end link bolt maybe 1/2 turn. Well that was all it took to have a nasty clunk noise from the front right when I turned or when over a small bump. That was a easy fix though.
PM me if you want me to help out any more
acurajj
02-14-2016 02:28 PM
EvilVirus
12-10-2015 07:38 PM
