hubcentric rings
Old Aug 4, 2008 | 05:11 PM
MurdaZ's Avatar
hubcentric rings
whats better, plastic or aluminum?
im an idiot, and now realized that theres a 9mm bore difference with my rims and hub, and now bet that its the space that is causing my vibration...
Old Aug 4, 2008 | 05:19 PM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
I had plastic ones and they seemd jus fine to me...
Old Aug 4, 2008 | 05:35 PM
01tl4tl's Avatar
either is fine- whatever the local tire store has- I run plastic on mine
Yes it will help a lot on vibrations- without them, its possible to have the rim not dead center on the lugs
Old Aug 4, 2008 | 05:36 PM
MurdaZ's Avatar
also to confirm, our centerbore is 64.1? i saw some threads people pointing out 64.1 and 64.0 so just wanna make sure, cuz i bet every mill counts...
Old Aug 4, 2008 | 05:39 PM
ZEUS'O3TL's Avatar
that is correct sir....64.1
Old Aug 5, 2008 | 08:21 AM
NSXNEXT's Avatar
Yes, 64.1 and plastic is perfectly fine. That's what I used with my wheels.
Old Aug 5, 2008 | 02:51 PM
SiCrew's Avatar
^Yup, same here.
Old Aug 5, 2008 | 04:20 PM
TLer trash's Avatar
Plastic ones tend to work better in winter/salt as far as not seizing onto the hub, but I've seen them melt on a track car. Aluminum ones won't melt, but I've seen them split from corrosion, and/or seize onto the hub. It's a rust belt thing!
Old Aug 6, 2008 | 07:30 AM
kaptainjack's Avatar
YoungatHeart
wheel manufacturer provided plastic hub rings with my wheels (menzari)...no vibration at all after install.. ....interesting points about meltdown vs. cracking...guess we'll wait and see...enjoy
Old Aug 6, 2008 | 11:39 AM
Edward'TLS's Avatar
6G TLX-S
One of my plastic ones was sheared into halves (became two rings) before. Metal ones are definitely a lot stronger.
Old Aug 6, 2008 | 10:34 PM
CJITTY's Avatar
Ackniculous One
I love my aluminum ones, the plastics got brittle and started cracking
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
johnalfa
Oct 31, 2015 12:55 PM
mtl_ilx
Sep 3, 2015 09:48 AM
