Help With Size For New Rims
I'm looking to order a set of bbs lm reps for my just need some help with sizing
I'm going to be doing 19's with 8.5 up front 10.5 out back (I think that will give it a nice look without sticking out alot)correct me if im wrong tho
will there be any clearance issues i will be lowered on coils with rolled fenders
also what the correct offset to run
Don't know much about offsets n all that stuff so bare with me on this one guys
8.5 +30 should be flush in the front.
the 10.5 in the back will require fender roll and fender pull. also the offset will have to be lower than +38 to avoid hitting the coilover with the inside of the rim.
and then you have to worry about tire sizes....
use this to help you out:
http://www.rimsntires.com/specs.jsp
http://tyrestretch.com/
Okay so i lied....i will be doin 9.5 all around on 19s, after tryna find the size i want and talking to a few local shops and now looking back on the post staggerd on fwd is a no... which offset should i be running on if they are 9.5 all around?
ExcelerateRep
10-14-2015 08:20 AM
