Help! F2 Type 1 Coils on, Upper Control Arm hitting
Old 11-28-2011, 12:26 AM
  #41
cu0ngsayz's Avatar
Originally Posted by Accordcg
So whats the best thing to do in this case ?
Don't ride slam...???!!! Raise your car?!?!? Hahah don't be maxed out on FF cause that is like riding on bags with no air.... Hahah
Old 11-28-2011, 09:29 AM
  #42
rockstar143's Avatar
Received 19,961 Likes on 14,481 Posts
^^^all true and all good suggestions.
Old 01-01-2012, 01:34 AM
  #43
bucsteve's Avatar
i think im one of the lowest tls on this site....how come i dont have problems like you guys?
Old 01-01-2012, 12:40 PM
  #44
kill you till you die
yeedatoy's Avatar
do you run FF1?
Old 01-01-2012, 03:38 PM
  #45
n1njai's Avatar
Debatable. We'll start with everyone has this issue because they're lower than you. If you don't have these issues, you either
A. Don't drive much.
B. Drive in a nice city with super smooth roads.
C. Are so godlike with your driving skill that you avoid every little bump/hole/speedbump/bad road.
Old 01-01-2012, 05:17 PM
  #46
MechEng
03tLsNBP's Avatar
i've been to San Diego. every road i drove on there was as smooth as a baby's bottom.
Old 01-01-2012, 07:01 PM
  #47
yeedatoy's Avatar
I'm pretty sure he's on Ksports, not F2...I almost didn't buy F2's because of this....I really dont think the type one is that good of a coilover but I didnt want to spend any more money. Hell. I couldn't even afford the type ones but I bought them anyway. Now I'm doing all kinds of horrible crap to pay them off!
Old 01-01-2012, 07:26 PM
  #48
yeedatoy's Avatar
Searching through other forums it seems most with F2 have this issue when they sit too low. Its all over the civic forums as well. I see people just as slammed if not lower riding on Tokicos with ebay sleeves, Ksports, etc and the issue isn't there. Kinda sucks, I wonder if the type 2 have this issue.
Old 01-02-2012, 10:25 AM
  #49
swllen_cu's Avatar
The Type 1's are too soft to ride compeltely slammed, ksports can do so since theyre qutie a bit stiffer.
If you want to ride slammed with no issues, don't buy ff type 1... The type 2 helps a good bit since you can stiffen up the ride with the adjustable dampening.
yeedatoy (01-02-2012)
Old 01-02-2012, 01:33 PM
  #50
Meridian
VoLLy's Avatar
Shortening the preload spring travel also helped for me...I could even go 1cm lower than before and it still wouldn't hit. Thanks xtremex626!
Old 01-02-2012, 01:40 PM
  #51
swllen_cu's Avatar
^ Yeah I did that too, it helped some.
Old 01-02-2012, 05:20 PM
  #52
yeedatoy's Avatar
Do you guys remember how much your preload is adjusted? I was thinking about going 1/4"
Old 01-02-2012, 05:40 PM
  #53
yeedatoy's Avatar
Nevermind, just caught it on the first page.
Old 01-11-2012, 01:34 PM
  #54
bucsteve's Avatar
Originally Posted by yeedatoy
do you run FF1?
ksports
Old 01-11-2012, 01:37 PM
  #55
bucsteve's Avatar
wow...this was exactly wat i was about to write.
Old 01-11-2012, 01:43 PM
  #56
yeedatoy's Avatar
how low were you? I feel like I'm lower than you and mine don't hit at all on stock preloads.
Old 01-11-2012, 01:50 PM
  #57
bucsteve's Avatar
san diego roads are nowhere near smooth as a baby's behind, you must have been around the nicer area of town.
Old 01-11-2012, 01:52 PM
  #58
Well, if he was mentioning behinds...must have been the Hillcrest area
Old 01-15-2012, 11:05 PM
  #59
cu0ngsayz's Avatar
I'm on ksports and I have this problem too... But I just TRY to ignore it hahhaha
Old 01-17-2012, 08:53 PM
  #60
VIP TL
cdn_rider's Avatar
thank haysoos i found this, was about to ask why im getting a clanking but only on one side, makes sense now. im not even that low, im on the highest settings which is still pretty damn low.
Old 01-17-2012, 10:41 PM
  #61
yeedatoy's Avatar
Are you sure it's the control arm? scroll up to my pic, I don't hit at all. Not even with an extra 400lbs up front Driver/passenger.
Old 01-17-2012, 11:07 PM
  #62
-Arsenic-
02type-s's Avatar
Once they break in and loosen up, they will. Trust me, they will. lol
Old 01-18-2012, 01:39 PM
  #63
swllen_cu's Avatar
You don't have much problems because your rear is dumped compared to your front. Put the front at 23.5 and you'll have problems. Haha I was at 23.5 before and hit my control arms all the time on big dips and uneven parts of the road. I raised it to 24" to save my oem front lip. Lol
Old 01-18-2012, 01:44 PM
  #64
swllen_cu's Avatar
And I'm seriously thinking about taking off my lip kit and going lower now that I'm seeing a lot of cars slammed with stock body. It makes it look so cleAn! Lol
Old 01-18-2012, 08:15 PM
  #65
yeedatoy's Avatar
But he said his were raised all the way up! How does the car handle at your height? Only reason I ask is because the TL looks lower in the rear at stock height and after lowering spring installs. Even though it looks lower in the rear it's an even drop all the way around and with my teins the drop was .25 lower in the front but still looked higher than the rear, and for the car to be dropped another .5 in the front would make the front end an actual full inch or so lower then it was meant to be in the front. I just don't want to screw the handling dynamics of the car, and if I lower the front more I'll have to remove the fender liner. I'm afraid I'll soak my CAI in the rain. are you running a stock intake or CAI? I'm considering selling my rear and sides as well instead of getting them painted but the front lip is staying until I destroy it..lol
Old 01-18-2012, 08:16 PM
  #66
yeedatoy's Avatar
nevermind..just saw your sig. You have no issues with the liners removed? I assume your's are as low as your car is.
Old 01-23-2012, 03:24 PM
  #67
swllen_cu's Avatar
I rubbed them from time to time, but what I did was cut the fender line in the middle portion of the fender and left the portions connected to bumper and the door intact... That way I could bent the fender tabs up a little bit for more clearance. I know it sounds confusing, but i'll take a pic for you to clear things up
And meh, the car handles ok. I honestly don't like the way the FF type1 ride... The rear is bouncy.. I was thinking about the new coils that XLR8 is offering or some tein basics or SS
yeedatoy (01-23-2012)
Old 01-23-2012, 04:34 PM
  #68
yeedatoy's Avatar
Okay thanks, I know what you mean, I was thinking of doing the same but I wasn't sure if that was possible without the leftover portions falling out. I've had liners go flying off on the freeway before! You're right, the rears are bouncy. I'm not familiar with how they handle without my larger sway on though.
Old 01-27-2012, 07:20 PM
  #69
VIP TL
cdn_rider's Avatar
alright guys so i thought this was my problem but its not. it turns out this clunking only happens in cold weather and by cold i mean fucking cold, canadian cold -20 or more.
are these coils not good in the winter and have issues like this? clunking goes away when its warmer.
Old 03-29-2012, 09:06 PM
  #70
3g-s's Avatar
3gs have more space but i guess im past that point i am really thinking about weildng in a dome where my upper balljoits are
Old 03-29-2012, 09:22 PM
  #71
3g-s's Avatar
raise your car back up?? what kind of answer is this wheel gap is the enemy
Old 04-07-2012, 12:57 AM
  #72
feixjai's Avatar
Sorry to go off topic, but I have this problem too and I'm on stock suspension..
Old 04-14-2012, 10:22 AM
  #73
..PRAXIS..
02ACTcLean's Avatar
This.
This is just the first step in the process to ride super dumped and NEVER have to worry about arm knock.
Too lazy to host a picture of it, once you get your desired holes cut, weld a raised box around the holes to retain the structural integrity. in the procees of doing that myself. will post pics once im all done.
02-25-2020 09:57 AM
marcelft
07-10-2018 06:17 PM
Aging-Hacker
10-05-2015 11:44 AM
gqdabien
09-08-2015 11:41 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Help! F2 Type 1 Coils on, Upper Control Arm hitting
