Does the 3rd gen sway bar fit on a 2nd gen?
6G TLX-S
Always replace the sway bars (front and rear) as a set, unless you know what you're doing. Stiffer sway bars will alter the handling dynamics of the car.
Stiffer rear sway bar will increase the understeer tendency of the car. So if you overdo it, your car's rear end may catch up with the front under some braking and drop-throttle situations.
hmmm so then the thick progress bar may not be what we need? somthin like the CT or eibach bars that are a little thinner? cuz im definetly not tryna crash! For those of you who have the progress bar do you think that it makes the understeer increase a substantial amount to the point where its dangerous or it just keeps the car from swayin everywhere?
AZ Community Team
Received 7,771 Likes
6G TLX-S
Thanks for the correction. My fingers aren't following my mind these days !
Stiffer rear sway bar will increase the OVERsteer tendency of the car. So if you overdo it, your car's rear end may catch up with the front under some braking and drop-throttle situations.
6G TLX-S
Here are some 2G TL/TL-S aftermarket sway bar thickness numbers for your reference :
Suspension Technique = front - 22.2mm, rear - 19mm.
CompTech = front N/A, rear - 22mm.
Eibach = front - 27mm, rear - 23mm.
H&R = front - 26mm, rear - 22mm.
Neuspeed = front 27mm, rear - 19mm.
Now you tell me if the 24mm rear bar only is overdoing it or not.
hahaha aite point taken. its just that alotta people were sayin get the progress rsb which is 24 i believe but you have changed my mind and provided a very relevant point! thank u sir!
AZ Community Team
Front 27.4mm Hollow
Rear 19mm Solid (TL-S); 18mm Solid (TL)
03 ABP tls
i ordered progress one just last night, based on the positive experience others have had. i dont have a front yet but ill be looking for one a few paychecks from now haha. cant wait to see how it handles with a drop and the RSB
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
