Do these rims fit?
Do these rims fit?
http://www.maxspeedperformance.com/x...d=12812&cat=30
I really like the style of these rims. But the only question I have is that will it fit on my 03 tl-s? also, if i get h&r springs and koni sp3 shocks will there be any problems with the fitting or rubbing? thanks.
Avant Garde Wheels
^ make that 100% that it will fit if OP puts on the effort to make them fit haha. I fit 9.5 +34ish in the rear with some neg camber with roll with light pull. Also trimmed my rear bumper tabs. Tires were 225/35/19 so I stretched them quite a bit. Frot would have more room for clearance.
what do the different hub numbers mean? i.e. 73, 72, 67, 66...
also,does higher offset mean that the rims would be closer to the schocks/springs or away? the offset really confuses me because i know you can measure it like positive or negative. and it means how far away the mounting surface is from the center half line of the rims. please help, thanks!
..why not just buy my wheels ? Oh right, I forgot.. you like to flake and make excuses... lols.
BTW, higher offset = wheel/hub is closer to vehicles centerline. lower offset = wheel/hub is further from vehicles centerline.
i already apologized to you about whatever happened. i also tried to meet up with you but obviously i was busy due to the holiday season. i do have a life other then looking for a set of rims for my car. but you might not understand that because you don't have any? lols.
