DIY: Raising/Lowering Function&Form Coilovers
Old Nov 22, 2009 | 06:18 PM
SLushhYYY's Avatar
Keep It Simple in
This may seem obvious but people are asking others on how this process works, so for those PM'ing Josh and others asking how to raise/lower the coilovers, here is the simple 3 step method.
Step 1: Loosen Gold Ring by turning it to the left
Step 2: Grab the treads and depending on whether you are raising or lowering turn the inside treads with your hand. (It is much faster this way, using the damn wrenches takes to long)
Step 3: Lock the gold ring by turning it right.
Enjoy!
Old Nov 22, 2009 | 08:21 PM
friesm2000's Avatar
B A N N E D
might want to also add to also make sure the threads are clean so it spins easier if your shocks are not quite as clean as his /\
Old Nov 22, 2009 | 10:14 PM
jjashaa's Avatar
Avant Garde Wheels
thanks! lol
and its turn gold ring to the right to unlock
left to lock.
Old Nov 22, 2009 | 10:24 PM
SLushhYYY's Avatar
Keep It Simple in
My arm hurt really bad after raising my car.
Old Nov 22, 2009 | 10:29 PM
jjashaa's Avatar
Avant Garde Wheels
^ lol.. thats what the wrenches are for.
Old Nov 22, 2009 | 10:37 PM
SLushhYYY's Avatar
Keep It Simple in
Pshhh, It took me 2 mins per side to reach the max height....its worth the pain
Old Nov 22, 2009 | 10:38 PM
friesm2000's Avatar
B A N N E D
no it's because he thought he was Arnold Schwarzenegger, but in realality he is Pee-wee Herman
Old Nov 23, 2009 | 12:24 AM
bayareatltypes's Avatar
lower=better on anything
Old Nov 23, 2009 | 02:53 AM
klectic's Avatar
The most simple, yet informative DIY. Good stuff!
Old Nov 23, 2009 | 02:37 PM
CJITTY's Avatar
Ackniculous One
Comic Book Guy Sez: "Best Azine DIY Everrrrrrrrrrrrrrrrrrrrrr" lol
Old Nov 23, 2009 | 05:37 PM
Hitman187's Avatar
Arrow
Thoroughly Written.
Old Nov 23, 2009 | 08:39 PM
Rajca's Avatar
wham bam thank you ma'am
not for racing.
Old Nov 23, 2009 | 08:47 PM
friesm2000's Avatar
B A N N E D
so you like nice low saggy boobs or being limp
Old Nov 23, 2009 | 08:57 PM
Rajca's Avatar
saggy, limp, lifted, u can still motor boat them
Old Nov 23, 2009 | 09:17 PM
friesm2000's Avatar
B A N N E D
Old Nov 23, 2009 | 09:33 PM
SLushhYYY's Avatar
Keep It Simple in
not for racing.
x2 I've noticed that the car handles better on touge runs
Old Nov 23, 2009 | 11:07 PM
saggy, limp, lifted, u can still motor boat them......lol
dont wanna drive a 4x4
Old Nov 23, 2009 | 11:31 PM
friesm2000's Avatar
B A N N E D
then it sounds like you need some fat chicks to ride along with you to get that low look, and be able to motor boat them where ever you want to
Old Nov 24, 2009 | 10:25 AM
Neejay's Avatar
Now, where does pre-load come into play?
Old Nov 24, 2009 | 10:33 AM
Neejay's Avatar
EDIT: After re-reading, I see you left pre-load alone and adjusted the correct way, right?
When I had coilovers on another car, the spring was the only thing you could adjust the height by, not the bottom mount...so I'm inexperienced with the RIGHT way to adjust coilovers.
Old Nov 24, 2009 | 11:00 AM
SLushhYYY's Avatar
Keep It Simple in
These are a different kind of coilover.
Old Nov 25, 2009 | 03:40 AM
. N B P .'s Avatar
Nighthawk Black Pearl
nice write up
Old Nov 28, 2009 | 04:49 PM
al8er7's Avatar
What car model for the F2's did you get them for? TSX/Accord?
Old Nov 28, 2009 | 05:13 PM
klectic's Avatar
From my understanding, F2's, PICs, and I think D2s, KSports have independent height and preload adjustments so that's why your adjusting from the bottom. Something like Teins (or just sleeves) your "adjusting the spring" so it affects the load.
So it really depends on which coilovers you have, not really a right/wrong way to adjust them..
Old Nov 28, 2009 | 05:45 PM
friesm2000's Avatar
B A N N E D
for preload, you just snug up the spring so it touches and has a little pressure on it to hold it in place; ie: when the lift/jack the car up and the shock is at full extension the spring is still snug enough that it will not get dislocated/shifted out of place when the car is let back down (also think about what would happen if you happen to get a little air when driving at speed)
Old Nov 28, 2009 | 05:47 PM
SLushhYYY's Avatar
Keep It Simple in
99-03 TL 98-02 Accord
Old Dec 15, 2009 | 09:38 PM
Spoilaz's Avatar
How much lower than stock is the max setting on the FF's....Thinking of getting them but would like to still be able to drive in NY winter
Old Dec 15, 2009 | 09:46 PM
SLushhYYY's Avatar
Keep It Simple in
^^1 finger gap in front 2 finger gap in back
Old Dec 15, 2009 | 09:49 PM
friesm2000's Avatar
B A N N E D
like so you are not tucking cause i am that low on h&r's and bilstein's
Old Dec 15, 2009 | 09:53 PM
Rajca's Avatar
thats not low at all.
Old Dec 15, 2009 | 10:06 PM
SLushhYYY's Avatar
Keep It Simple in
This---is after i raised it all the way in the DIY
This was how low I was in the first pic of the DIY
opposed to this--
Old Dec 15, 2009 | 10:07 PM
friesm2000's Avatar
B A N N E D
those tires look small for some reason, are they the same diameter as the stock tires???
maybe try a striaght on side shot at ground level with a pop can or something for reference
Old Dec 15, 2009 | 10:09 PM
SLushhYYY's Avatar
Keep It Simple in
^^18x8 w/ 215/40/18 in front and 225/40/18 in rear
Its cuz they are angled in both pics
Old Dec 15, 2009 | 10:16 PM
friesm2000's Avatar
B A N N E D
the fronts are like 3/4 of an inch too short from the factory size and backs are only like 1/2 an inch too short
Old Dec 15, 2009 | 10:20 PM
SLushhYYY's Avatar
Keep It Simple in
Just for you sweetheart
Before
After
Old Dec 15, 2009 | 10:28 PM
friesm2000's Avatar
B A N N E D
and why you go higher, it's not like you got any winter weather to deal with
Old Dec 16, 2009 | 10:49 AM
klectic's Avatar
^ That's the one thing I don't like about F2's is the adjustability range. Almost at the highest for the fronts and it's still pretty low.. if it were able to raise the front like how the rear when fully raised it would work better for me (damn Canadian winters!)
How high do you think the limit would be for raising the fronts on the sleeve (eg. on step 3 pic, are your collars alll the way to the top?)
Old Dec 16, 2009 | 10:58 AM
SLushhYYY's Avatar
Keep It Simple in
^yep
Old Dec 16, 2009 | 04:45 PM
MurdaZ's Avatar
wow i wish i lived in a hot climate.......your coils are like brand new.
Old Dec 16, 2009 | 05:13 PM
SLushhYYY's Avatar
Keep It Simple in
^^They are brand new
Driving is funner when you dont have to worry THAT MUCH about bumps and stuff.
