Diff. between tl and cl offset
Old Mar 3, 2005 | 04:38 PM
mikey3.2's Avatar
www.grounded4life.org
can some on tell me the difference between my 99 tl n a 02 cl offset. im lookin on gettin a set of wheels i seen on a 02 cl that were 7.5 wide with a 42 mm offset n thet didnt stick out in the front n didnt rub in the back will these work on my tl. THANX
Old Mar 4, 2005 | 12:19 AM
Lawaia's Avatar
Moderator Alumnus
Offsets are the same. Wheel width differs between tl-p and cl-s by 1/2".
Old Mar 4, 2005 | 03:45 PM
mikey3.2's Avatar
So The Cl-s Is 1/2 Wider N Will The 42mm Offset W/ A 7.5 Wide Work On My Tl With Out Stickin Out
Old Mar 4, 2005 | 05:54 PM
StanMan's Avatar
lawaia was referring to the stock rims. both have 55 offsets. i believe both cl and tl non type s cars are all 6.5 wide, but the cl-s is 7" and the tl-s is 6.5".
i had 18x7.5 with a 42 offset and 225/40 tires, and it did not stick out on my 02 tl-s. i also had the camber in the rear corrected and it was just shy of flush. you can check for pix in my sig. however, i did rub some of the rear bumper because of the camber kit but a lil trimming fixed it. if you leave the camber in, it should be alright. i believe the cl has bigger wheel wells so although it might be at the limit for the tl, it will be a better fit for the cl.
neuronbob
23
Jul 16, 2019 10:48 AM
BreezyTL
Jul 26, 2016 12:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
