Coils VS Springs/Shock
Any input? I've been reading you guys comments and noticed that you guys say you regret getting the springs and should've got the coils first. Im stuck in a pit right now, here are my choices.
FF Type 1
or
FF Type 2
or
Koni yellow shocks/Eibach Sportline Springs. *are these the springs that will get me the lowest compared to others?
Spring/Shock combo route would be the best financial route for me though, broke college student![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Keep in mind i made this thread for input because my friend has coils on his FG2 and hes switching over to the new shocks/spring combo.
I AM looking for both a drop and performance. I mainly want my car to look like a fellow member's car. I already have the wheels, i just need the drop.
FF Type 1
or
FF Type 2
or
![](http://s3.amazonaws.com/data.tumblr.com/tumblr_lwxo7g03u51qbkdeco1_1280.jpg?AWSAccessKeyId=AKIAJ6IHWSU3BX3X7X3Q&Expires=1325859082&Signature=Dfpo3ysmxaSfGhaKdQ6uStxkUjw%3D)
03tLsNBP (01-05-2012)
I was thinking
Koni Yellows & Eibach Sportline
is that combo more expensive then the FF1? o.o
I measured everything earlier and the springs/shocks seems best bet, from the floor to my fender is 27inches, my tsx wheels with new tires are about 25.5inches and the sportline drops me 2.25-2.5 right? That evens out basically
MechEng
I was thinking
Is it possible for me to get FF type 1 and change the springs? I seriously did not think the shocks were 600 alone.
*Edit, would it be better to keep the stock FF type 1 springs or change them out to something else?
rebmeM deretsigeR
Get a set of used coilovers. Got my Tein SS for 540 only. Had some rust and were dirty as hell, but still work great. Shop I bought them from couldn't believe they were the same coilovers after I cleaned them up.
kill you till you die
Koni/Tokico have a lifetime warranty only when you are dropped a certain amount. If they think you were too low, you're not covered. Tokicos warranty wont cover you if your'e dropped over 1.5 or 1.7.....somewhere around there. If you want a low priced coilover that lowers your car as much as you want but don't care much for performance then go with the FF type one. If you're willing to spend a bit more for better performance, go with an adjustable damper like the Megans or FF type 2. Tein coilovers will get rid of your wheel gap but wont get any lower, but from what I understand they are still a bit of a soft ride but Tein is quality stuff. Neuspeed Race springs go the lowest as far as springs go from what I've seen http://www.customcarscentral.com/neu...d--98-02-.html
None of those coilover setups should be better performance wise than a good strut/spring setup. Tokico Illuminas/H&R or Koni/H&R would be awesome performance wise, but with any of the lower spring setups you'll have to live with a 1-2 finger gap.
jjasha, are the Koni's for the TL height adjustable like some of the others? I know they usually have 3 height settings on the actual damper...if thats the case you could go .25 lower I believe.
You're right, just found it. They go 20mm lower which is about 4/5 of an inch. So technically you could drop over 3 inches on these struts and springs? It says they adjust at the perch though, so that would change the preload correct? I think I'm confusing myself here.
Sisters know all too well about slammed cars, sisters bf's have them too. They just keep telling me stop putting money in the car cause im gonna have another one sooner or later.
