Centerbore
Centerbore
Ok, I bought some wheels that have a smaller center bore than the hub centerbore, so they don't fit. I'm going to a machine shop to get it bored out. I've searched the forums but came up with inconclusive old threads. what is the size of the centerbores.. 70.1mm?
Also is it better to tell the machine shop to cut it bigger , for example 70.5 or 71 to ensure that it will fit?
appreciate any feedback.
'03 ABP YA4-S 6MT
Originally Posted by stylesinfinite
thanks so much guys, appreciate it!
should I ask them to cut it 64.5 or 65? what would be better..
64.1, keep it the stock size so it fits. You can go larger but then you would have to get hub centric rings.
Originally Posted by rp_guy
why wouldn't you just get it to 64.1??? if it's any different from 64.1 you will be lug-centric... and should have to buy a hubcentric ring (i'm not even sure they make anything that small)
thanks again
Ok, I called up a bunch of machine shops to cut the center bore of 56.1mm on my wheels to 64.1mm, so I can fit it on the hub and they all refused. A couple guys explained to me that this would ruin the structural integrity of the wheel.
I've done some research and found that some wheels are engineered according to the size of the centerbore. So would boring the center out like that ruin it's structural integrity? Should I keep searching for a machinist who would cut it or is there some sort of hub adapter?
It all depends on how much material is there to begin with. Most rims are blanks and bored to the desired size in manufacturing.
They dont have to remove very much to get that but if there isnt much there it would. Have you brought the wheel in to a machinist to have them physically see it?
Also whats this going to cost? Id just look for wheels that fit
May cost more to have them made to fit than the loss you would take by getting properly fitting wheels.
Dan Martin
285
07-23-2014 12:23 AM
WalkerUA6
01-06-2009 02:46 PM
BacktoAcura
06-13-2007 03:14 PM
