Camber Adjusting Ball Joints vs. Adjustable upper arms
I am planning on replacing some bad ball joints in my '02, and am planning to eventually lower it.
I've never used the adjustable ball joint camber links before and wanted to know if they were any good when compared to a "real" adjustable upper arm kit which is what I am used too and have experience with.
At first glance they seem like they would need regular adjustment, and frankly seem wonky. Anyone with experience with these? http://www.moogproblemsolver.com/ste...ent-ball-joint
I had them for less than 30,000 miles before they wore out. I was only dropped about 1.5", but the additional height caused them to hit over even modest bumps. I put oe back on, had about -1 deg camber, and rotated every 5,000 miles.
Are the upper ball joints replaceable in our cars? I need to replace mine and i don't want to replace the control arm if i can just do the ball joint.
Yes, they are, BUT personally, i would pick up new control arms that have the ball joint in it. Reason being is that the bushings in the end of the control arms do wear out, and given the age of the car now i would just replace the entire thing. Not to mention it would be faster and easier.
Toe is adjusted via the steering tie rods. Ingalls makes adjustable camber control arms.
Ingalls Alignment Kit - Excelerate - HOA - Japanese Performance Specialist
Welcome to Acurazine Capo Shaw. Sorry to hear about your cancer.
Did you change the upper arm yourself? it's very strange that you have any change in camber after changing out suspension parts, the camber is non-adjustable so the parts are all built to spec. Could be possible that you have a worn suspension bushing on your lower control arm (LCA), that would be my next place to look at.
Yes, doc says it's getting real bad
Yes I changed upper and lower arms myself
adreano17
09-29-2015 08:48 AM
