Brake bleeding sequence
Old Mar 5, 2009 | 10:35 AM
RichTm3's Avatar
Smile Brake bleeding sequence
Does anyone know this? is it LF, RF, RR, LR?
I did a 88 Honda one time and it was LF, RR, RF, RR which is not typical.
Old Mar 5, 2009 | 03:52 PM
formula1's Avatar
That is the correct way.
Old Mar 5, 2009 | 06:45 PM
01tl4tl's Avatar
confirmation: Its driver front then clockwise around the car
LF RF RR LR
DOT3 or DOT4 fluid approved
If it says 3 on th emaster cyl cap- then 4 is ok,its the newer better spec
If it says 4 then only 4
Synthetic or reg -your choice- get 2 qts, should take 1 to 1.5 to get all the old fluid pumped thru the system
No dont use 5.0 in a TL ever!
A turkey baster to remove most of the old fluid from the master is a good 2 dollar investment.
Old Mar 5, 2009 | 06:46 PM
01tl4tl's Avatar
Its because of the ABS plumbing that the TL has this special order and it must be followed
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
