bolt pattern/ offset
Registered Abuser
Can someone tell me what is the exact bolt pattern and offset on a 03 TL-S.
Also when buying aftermarket rims, does the bolt pattern and offset have to match exactly??
Registered Abuser
I also forgot to mention that I know nothing regarding this topic, can someone quickly explain what bolt patterns and offsets are? Thanks.
Received 1,080 Likes
Bolt pattern: 5x114.3
OEM TLS wheels: 17x6.5
Offset: +55
Does the bolt pattern and offset have to match?: Bolt pattern Offset
Here are the specs for aftermarket wheels:
18x7.5 +45 225/40 18 tires (need to be +45 or greater offset)
18x8 +50 225/40 18 tires (+50 is an ideal offset for 8" wide wheels)
19x8 + 50 235/35 19 tires
This is assuming you have a modest drop (HR OE or Sport or Comptech))
I believe bolt pattern refers to the number of bolts and the distance between each one.
OFFSET
Offset: +55
OFFSET
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
