Axis Penta
Old May 4, 2010 | 02:29 AM
andrew77's Avatar
9th Gear
Axis Penta
Does anyone know if the 18x8 or 19x8.5 Axis Penta will fit on an 02 TL (5x114.3)?
Thanks.
Old May 4, 2010 | 08:02 AM
NSXNEXT's Avatar
Possibly. You need to find out what the offset is. +40, +45 or something else?
Old May 4, 2010 | 08:06 AM
NSXNEXT's Avatar
http://www.nlmotoring.com/category-s/455.htm
Looks like it comes in 18x8 +40 which will require some mods to the fender liner and possibly rolling the fender.
Are you/are you planning to lower the car?
Old May 4, 2010 | 10:57 AM
andrew77's Avatar
9th Gear
My car is already lowered. 1.5 in front and 1 in the rear (not too agressive). I want the axis penta rim on the car but the whole offset thing has been a problem for me. Do you know if I could go with an 18x8 without having to modify anything? I've seen the Penta on the 3G TL but not on the 2002.
Old May 4, 2010 | 01:36 PM
Mista Juice's Avatar
with the 18x8 +40 you shouldnt need to mod anything.. i would cut the tabs in the rear just in case (not hard at all), but you really shouldnt have much to worry about..
Old May 4, 2010 | 02:18 PM
andrew77's Avatar
9th Gear
When you say "cut tabs" what are you referring to exactly? I gues my question is this: What are the tabs and where are they located? Thanks.
Old May 5, 2010 | 08:19 PM
you should be able to find some pics by searching.. the "tabs" that you cut are where the rear bumper meets the fender.. the bumper has "tabs" that the tires rub sometimes if the offset is a bit lower than usual when you are lowered..
Sep 14, 2015 10:10 AM
brianlin87
May 2, 2004 05:08 PM
yi_yi
Apr 11, 2004 05:59 PM
musclehead
Apr 3, 2004 12:54 AM
Ahmad310
Sep 20, 2002 04:02 PM
